iPhone 7 Will Revolutionize Portable Audio for the First Time in a Decade
Sep 9, 2016 at 9:57 AM Post #271 of 1,216
It's a well laid out thought.
Still some engineer who knows that the Lightning port setup has ¡already explained us that it's just not possible to pump analog stuff through the Lightning port. I'd like him to be wrong but i am afraid his view is on the money.
Is that in this thread? Sorry if I missed it but this is literally make our break for me on the 7. If there's some tiny DAC in that adapter rather than passing analog through to my headphones then I'm out for sure.
-Collin-
Sep 9, 2016 at 10:01 AM Post #272 of 1,216
-Collin-
Yes it is. It's a few pages back but there was a lengthy discussion/argument over the topic. It appears pretty clear though that you cannot pass an analog signal through the digital lightning port and so the adapter actually has a built in dac/amp. Believe it was actually confirmed when looking at the specs for the adapter that apple posted.
Sep 9, 2016 at 10:03 AM Post #273 of 1,216
Damn, that's terrible. I don't even want to imagine what kind of DAC comes in a $9 adapter. Probably about the same as that in my $17 BT workout earphones. Ugh.
Sep 9, 2016 at 10:14 AM Post #274 of 1,216
The discussion was about USB-C, which does allow for it and is in the propaganda Intel is pushing but has yet to be brought to market.
I agree there is nothing published saying it's possible with lightning and having a dac/amp makes the most logical sense in a lightning to 3.5mm adapter from what we know, but from the picture of the adapter, it looks to small. From what I can tell, the lightning end is the same size as current lightning cables which just has enough room for the authentication chip. The other end only looks big enough to be a female 3.5mm connector. To fit a dac/amp (from Cirrus Logic I presume), I would think one of the ends would need to be a little bigger. For instance, consider the lightning to 30 pin adapter with Wolfson chip (although part of the reason it's big is to put the 30 pin connector in it). If it has a dac/amp, it will be the smallest on the market, by far, that I've seen. Shrugs.
Sep 9, 2016 at 10:19 AM Post #275 of 1,216
This was exactly my thought, how can a DAC be in that connector.
Sep 9, 2016 at 10:30 AM Post #277 of 1,216
Because DAC/Amp Combos can be EXTREMELY small? I work in embedded design currently, and can absolutely gaurantee you there are DAC/Amps small enough to fit. Especially because in this design it wouldnt need any other design work behind it, you would just directly wire the the data+power into the pins on the DAC.
As far as powering the internal speakers, yes, there is likely a DAC in both the phone and the amp. DAC/Amps with orders of 1k+ are typically less than $10 per unit, dropping a cheaper DAC/amp into the phone for the internal speakers without increasing the cost whatsoever is completely feasable especially if it only has to power the internal speakers
for example, this DAC/Amp is only 5mm X 5mm
Sep 9, 2016 at 10:39 AM Post #279 of 1,216
This June article leaves me very relaxed and lesves my bank account shivering:
https://9to5mac.com/2016/06/29/cirrus-logic-mfi-dev-kit-lightning-headphones-iphone-7/
If Cirrus Logic is at the steering wheel i expect another day at the office with the dongle plugged in. It's gonna deliver...
If the tonality it's not right, then nothing else really matters.
Sep 9, 2016 at 10:43 AM Post #280 of 1,216
Yeah, I've seen some pretty small DAC/amps with Lightning connector already, but the trick usually is they put them in the housing for a remote control (like Audeze's Cipher "cable").
This tiny Apple dongle would have to put it in the little end with the connector itself -- I'll be (pleasantly) surprised if it has the same quality and power as the DAC/amp in my iPhone 6s Plus -- and they sell it for $9. They don't even sell Lightning cables for that little.
Sep 9, 2016 at 10:49 AM Post #281 of 1,216
Nice find. So maybe these new CL chips allow the space to be much smaller. Specs look decent and double the power of a ZX Walkman too.
Sep 9, 2016 at 11:01 AM Post #282 of 1,216
Nice post!
What has dismayed me most about this whole debacle has been the lack of empathy from those that believe we should all just man-up, get with the times, move on, progress, leave that 100 year dinosaur connector behind and fully brace the audio revolution that Apple has been courageous enough to start. Sorry, I just don't want to carry dongles or swap my SE846 for a pair of Bluetooth Beats headphones. This is about more than just a headphone socket. It's about a company I no longer trust. Yes, today it's just a headphone jack. What will Apple do tomorrow in the name of making even more money by gouging its customers progress?
I'm done with Apple and this thread. Time for me to move on. Good luck to all you folks with the dongles and the bluetooth.
Sep 9, 2016 at 11:02 AM Post #283 of 1,216
Yes, smaller, but notice that the enclosure is the body of the remote, which is still significantly larger than the end of the Lightning connector by a factor of about 4x.
Sep 9, 2016 at 11:06 AM Post #284 of 1,216
Agreed. Without controls it would be much smaller though, however still looks to big to fit in with the authentication chip in a normal lightning connector.
What would be nice is a case no thicker than the Apple silicone cases that have a nice competent dac and amp baked in, plus 3.5mm port. Many (most?) use a case anyway.
