iPad mini + camera connection kit + Dac = : )
post-9558503
Post #61 of 144
wingtsun
Scrap the iLuv hub. Won't work with the iPad. iPad says it draws too much juice...
post-9559619
Post #62 of 144
asianafrican
Darn.. So there's a chance that even if I buy a USB hub, it may not work huh :mad:
post-9559693
Post #63 of 144
wingtsun
Well, my conceptronics one works fine. The Dr Bott seems to work, too. I have a Dr Bott on order. I'd stick with ordering one of those unless you can actually demo it at the store.
post-9961527
Post #64 of 144
Muttley99
Hello im giuseppe from italy and now i will go to present myself in the right section,
im really interested on this 3d because ,i ve an ipad w lightning connector and i need to connect it to cambridge dacmagic (not plus edition)
The cable you mean is this?
http://store.apple.com/it/product/MD821ZM/A/adattatore-per-fotocamere-da-lightning-a-usb
could it work with my dac too?
Thanks all folks
I hope to give my little contribute to this great forum.
post-9961582
Post #65 of 144
Burju
I hope this helps too....I have tried them with iOS 7.03
This is the link to another thread.
http://www.head-fi.org/t/682222/ios7-iphone-and-apple-cck/150#post_9907243
Cheers
post-9961755
Post #66 of 144
Muttley99
To confirm.
I am using the Ipad mini > new lightning CCK > to dac
I also have the Lightning to 30pin, but will have to wait til next week to borrow the old CCK from cousin to try.
Thanks for the answer
I want to know if the cable who talk about hiyono is the cable in the link i attached n the last post.
I want to know if this cable extract digital audio to send via usb to my external dac
post-9969917
Post #67 of 144
Muttley99
It works with my ipad retina 4th gen 64gb cellular and dacmagic cambridge audio.
I don't know if the plus version of dacmagic works too 'cause it have a different (better) version of the usb input section too.
Thanks guys
Amo la mia Mini
post-10270279
Post #68 of 144
redstar
Can anybody confirm if:
Ipad Mini 1st gen (not the retina) > New lightning CCK > USB > Burson Conductor SL 1793 works
post-10337291
Post #69 of 144
bliss53
In an effort to use my Audioquest DragonFly 1.2 with an iPhone 5s and a iPad Mini Retina, I purchased an Apple Lightening Camera Connector Kit "CCK" (Apple Part No. MD821ZM/A) and a $20 portable Radio Shack usb hub (Part No. 2603763).  With the Dragonfly connected to the CCK then to the iPhone I got the "device requires too much power message" on the iPhone and no sound.  When I put the hub between the CCK and the Dragonfly there was no message and it worked fine.  Same for the iPad Mini.
There must be some monitoring feedback information that blocked by the insertion of the hub in the connection.  Hope this is helpful.
Question.  The hub is a bit awkward.  I think it would be cleaner and less likely to get caught up on something if the bus was really small.  Any ideas?  I was also wondering if the Audioquest Dragon Tail accessory would work.  Anybody tried it?
post-10337479
Post #70 of 144
HiFiGuy528
Member of the Trade: Woo Audio
Try the Apogee ONE for iPad/iPhone/Mac. The sound quality will blow you away.
post-10345794
Post #71 of 144
indieman
Hey guys! Just got my DF 1.2 in, and was able to get it working with iphone 5 as long as I used a usb hub in the link (worked with 2 different hubs, both unpowered, although being powered worked too, just didn't make a difference).
Not sure about the dragon tail, but I just tried a generic usb extender and it didn't work. Still got the power error message on iphone 5. Not %100 sure, but this means the dragon tail probably wouldn't work either since it's basically just a usb extender.
post-10352685
Post #72 of 144
indieman
~~Ok, I finally got around to testing out my DF 1.2 dac with my iphone 5s. Just like the iphone 5 I tested, there must be a usb hub in the link for it to work. Just for the heck of it, I tried a lightning to micro usb adapter and then the samsung otg cable. I was hoping it would throw the phone off like the hub and let me use the dac, but unfortunately it didn't even seem to register at all. Too bad, it would be much less cumbersome than a hub! Although tbh someone did tell me the samsung otg cable is very picky, so I'll have to try a universal micro usb otg cable before I can completely rule the idea out. Here's a few pics of an iphone case I modded to accommodate the usb hub and dac. Sorry for the bad quality, my only other camera besides the iphone is my surface pro tablet which seems to lack auto focus?
Here's a better pic of just the case
BTW it sounds incredible. Especially with lossless music (ALAC)
post-10365930
Post #73 of 144
bliss53
I think I found my solution.  Works on both the iPhone 5s and the iPad Mini Retna.  See the USB hub at http://www.amazon.com/Cute-USB-2-Port-Splitter-White/dp/B00A81ISJ6/ref=sr_1_1?s=electronics&ie=UTF8&qid=1394942486&sr=1-1&keywords=Cute+USB+Mini+2-Port+USB+2.0+Hub+Splitter+%28White.  Cost was $10.00.  Total cost $190 (CCK-$30, USB Mini Hub-$10. Dragonfly 1.2 $150).
post-10366999
Post #75 of 144
indieman
Cool! I've been looking for a smaller hub, will have to try that one out!
On another note, have any of ya'll experienced any issues using the usb hub + dac combo? I've been getting some sound distortion when adjusting the volume...
