SSSN
- Dec 7, 2013
Which Trinity Audio IEM has the most neutral bass?
Anyone has heard the new Master and can shed some light as to how it compares to the original Delta? I am considering doing the upgrade, but would like some indication about the sound.
I'm interested in the new Master as well. I'd like a bit more information regarding sound signature and personality. I can't stand wearing wires over the ear, so if the Master cannot be worn down I will opt out.
Have not follow Trinity closely since my Vyrus purchase so can anyone help me with what's the difference between the alpha delta hybrid and the new Phantom Master. It seems both are dual coil dynamic + dual BA so i'm not sure what is the distinct difference that justify their price difference. Thanks in advance.
Thank you so much for the clarification! So it's 2DD + 2BA in the Master while 1DD + 2BA in the Atlas Delta.All new Trinity products will be using their "dual-coil" driver, which is a single dynamic driver with two voice coils.
The Master has two dual coil drivers, set up in a push/pull configuration to reduce distortion. Also, I think the BA drivers used are slightly different to the Atlas-Delta, but don't quite me on that as it's just from memory. So, basic difference - two dynamic drivers instead of one, and set up in Push/Pull. Hope that helps?
Seems like someone doesn't like reduced microphonics or like 90% of earphones above 200 dollars
I posted some impressions of the pre-production Master and some comparisons up earlier in the thread - you should be able to find them using the search function?
To confirm, the ergonomic design of the shells and fixed cable above the Y-split will make it very difficult to wear these down - they have been designed to be worn over-ear.
Make that 2 questions - does the Atlas Delta have MMCX connectors? Which of the bluetooth cables will work?
nooe and they have a new one coming upMake that 2 questions - does the Atlas Delta have MMCX connectors? Which of the bluetooth cables will work?
