Introducing Lotoo PAW Gold
post-14498749
Post #4,261 of 4,534
west93600
When I use Sonore iso to dsd i check the box « convert dst to dsd »
and like output mode I choose raw iso.
I click to execute and I have my iso.
But when I go back to Xrecode I have always the same thing codec dst and I want dsd codec.
Please help me.
Thank you by advance.
post-14498982
Post #4,263 of 4,534
west93600
I do exactly the same things but it’s not working for me.
If I go back to Xrecode the codec for my iso file is the same.
post-14499088
Post #4,264 of 4,534
captblaze
Blazin it up in the land of Lincoln
can you rip the SACDs? perhaps trying those setting while ripped will change the codec? I had that setting when I redid my SACD collection and the ISOs that wouldn't play on the LPG are playing now... in fact the SACD in the screen cap I one that is in DST64 and needed re ripping
post-14507665
Post #4,266 of 4,534
Quadfather
Illinois
Illinois
Out of all my headphones, I think my Audio-Technica ATH-MSR7 headphones still may sound the best with the Paw Gold Diana! Even over my AKG-K812s.0927180710.jpg 0927180717.jpg
post-14508386
Post #4,268 of 4,534
Quadfather
Illinois
Illinois
Those msr-7's are a good thing - especially for the price
They seem to keep up with all my other more expensive headphones quite well.
Reactions: mulder01
post-14548513
Post #4,269 of 4,534
Quadfather
Illinois
Illinois
I am definitely going to hang on to my Diana. It just doesn't seem like you can find them at all in the USA anymore. Hopefully when the battery starts crashing I can get it replaced here.
post-14548970
Post #4,270 of 4,534
ruthieandjohn
Stumbling towards enlightenment
(Formerly known as kayandjohn.)
Poulsbo, WA, USA
Poulsbo, WA, USA
Two Service Needs And Their Resolutions: Bad Display, Intermittent Output Jack
I bought my PAW Gold used in October, 2016. In late 2017, its display started to lose brightness and take on a pink tint, as others have reported here. I wrote info@lotoo.cn, raising the possibility of also replacing the battery since it was already being serviced, to receive this prompt response:
“Since your machine is out of warranty, you have to pay for the maintenance fee. Because it is a waste of time and money to send the machine back to China, can we only send the screen? And you change the screen by yourself. Replace the screen is easy. Please see the video in the attachment.
“In addition, is the battery must be replaced? If you replace the battery, you need to send the machine back to us, because the battery can not be sent separately. If the battery does not need to be replaced at present, you can contact us when it need to be replaced in the future. If you need to replace the screen and battery, you have to send the machine back to China and pay for the whole freight(come and go). The fee for screen is $111, for battery is $111, the freight for the machine from China to USA is $84 by fedex, You need to pay us total $306. If you just want to replace the screen by yourself, the fee for screen is $111, the freight for screen from China to USA is $19 by SF EXPRESS. You need to pay us total $130. We accept paypal.
“Any questions, please feel free to contact us.
Looking forward to your reply.
Have a nice day.
Lotoo Customer Support”
After viewing the video, I felt I could perform the work myself, so I requested that they send a new display for $130 with shipping. I received the display within a week, and tried to do it myself. I had trouble replacing a ribbon connection, and so I resigned myself to sending unit back with the new display partially installed. That cost me $92 in Fedex shipping, plus another $84 for return shipping. Once in transit to Lotoo, I was told that there was a Customs hold on my player, adding another week and $30 import duty. Hence, I paid a total of $336. Turnaround was 26 days.
Then, in July, only four months later, my Headphone Out jack developed an intermittency in one channel. I suspected that stress on the connection, likely from a straight-in headphone jack applying leverage in my pocket and loosening the solder connection, caused the problem.
Again, I contacted Lotoo. They said if I could solder, I could reflow the solder and fix the jack. They sent a high resolution annotated photo. I again took my Lotoo apart, took a peek inside at the number of layers of stuff I had to remove, then again how much it would be for them to fix it. I again inquired about battery replacement. Here is what they said:
“If you are not confident in repairing the earphone jack by yourself, you have to send the machine back to China.
“This machine has had few customers changing batteries since it was launched in 2014. If it is used normally, the battery can be used for three to five years, but since the battery cannot be mailed separately, if you need to replace the battery in the future, you have to send the whole machine back to us. If you want to change the battery this time by the way, you can open the back cover of the battery, remove the original battery, and send the machine without the battery to us. After we installed the new battery, we will send it back to you, so that you have a spare battery. The cost of repairing the earphone jack is $45, the cost of replacing the battery is $105, the shipping cost from Beijing to the United States is $84, total is $234. And you need to pay for the shipping cost of the machine from the US to Beijing by yourself. In addition, if the tariff is generated(maybe about $30), you need to bear it yourself. What is your opinion?
“Sorry for the inconvenience and looking forward to your reply.
Best regards,
With the fee to send the PAW Gold from U.S. to Lotoo, the total with battery replacement would be $360. Without battery replacement, it would be $255. They cannot send the battery separate, for mail safety fire concerns...it HAS to be inside the Lotoo.
After a month of using the Line Out instead, I screwed my courage to the sticking post and tried to disassemble the player, revelry the solder, and reassemble it. I succeeded, but was nervous and still think that there is magic missing if I disassemble and reassemble over when the manufacturer does.
It now has been working great for about two months and is STILL my best sounding player (vs. Sony NW-1A and other lesser players.)
WHEW!! Great service from Lotoo! This leaves me questioning the wisdom of buying used, rather than new, for things I really love. However, it is only after I have them that I know that I love, not just like, an item!
post-14548993
Post #4,271 of 4,534
captblaze
My LPGD is on its 50th charge cycle and I am not having any issues. I am curious as to what type battery and whether or not there is a suitable alternative that doesn't require shipping back to China. and also mine being a Diana Edition I don't know if Lotoo would even touch it given the custom firmware and no ability to re flash it (at least for the consumer).
anyway I would agree that LPG stands on its own as a very capable player that gives you all the resolution and power you could ask for in a small form factor.
once charged I plan on lulling myself to sleep with a set of UE 18+ Pro and Diana singing through the gold hybrid cable connecting the two
post-14549014
Post #4,272 of 4,534
Quadfather
Illinois
Illinois
Have a nice day.
Best regards,
What headphones do you use?
post-14549041
Post #4,273 of 4,534
ruthieandjohn
Poulsbo, WA, USA
Poulsbo, WA, USA
I use nearly every Grado known, plus Ultrasone Edition 8, Sony Z7, and Fostex TH-900. All have in-line plugs...the only headphone I have with right angle plug is the Yamaha Pro500. I’ve used Grado GR10e, AKG K3003i, FAD Heaven VIII, FiiO FH5, and Sennheiser IE800, with only the last two having a right angle plug.
I had planned to purchase the new Lotoo Gold Touch, new, as I have been changing my desktop and several portable systems to balanced mode and the Lotoo Gold Touch gives balanced output. However, in careful listening with HD800, Grado PS2000e, Grado GS2000e, Sony Z7, and the FiiO FH5 through Schiit Gungir Multibit and Mjolnir2 DAC and amp, Sony NW A1, FIiO X5iii, and Lotoo PAW 5000, I hear minimal differences between balanced and single ended, and I really do like the sunburst good rocker wheel on the PAW Gold, and.., it seems that the Lotoo Gold Touch is taking forever to actually become available in the US, so I’m quite happy to stick with my PAW Gold indefinitely and use the FiiO X5iii and Sony 1A players for balanced portable use for those moments when I presume I can hear a difference.
Reactions: Quadfather
post-14549053
Post #4,274 of 4,534
Quadfather
Illinois
Illinois
I have Lotoo Paw Gold Diana, Questyle QP1R, and Sony NW-WM1A and love and use all three.
post-14549106
Post #4,275 of 4,534
golov17
Russia, Bashkortostan, Kumertau
Age
50
LPG testing of autonomy. 10 FW, High Gain, vol.50 of 75, earbuds 147 ohm, FLAC 24 bit 44, 48, 96, 192 pre-decompressed to zero compression, mixed folder with albums. In info battery 108 cycles. As a result: plays 10 hours exactly
Users Who Are Viewing This Thread (Users: 4, Guests: 8)
