Interesting machine from Luxury n Precision
May 3, 2022 at 5:29 PM Post #2,611 of 2,891
bluestorm1992
Virginia
Can anyone guide me through the process of getting all the tracks on my albums to be in the correct order?
Are you using Mac or Windows?
May 3, 2022 at 5:32 PM Post #2,612 of 2,891
bluestorm1992
Virginia
May 4, 2022 at 8:25 AM Post #2,614 of 2,891
NaittsirK
Croatia
Can someone maybe please share a few words on how to prepare an SD card for p6 pro ?
As I understand the sd card needs to be formated first to be used in the p6pro ?
Thnx
May 4, 2022 at 9:00 AM Post #2,615 of 2,891
bluestorm1992
Virginia
Thnx
Yes, you need to format it into FAT 32. Alternatively, the machine can also format the card for you once you insert it.
May 4, 2022 at 9:06 AM Post #2,616 of 2,891
NaittsirK
Croatia
Thanks!
Although I am really interested to hear how the sound from its ECC memory fairs against the sd card. (Yes I believe in that 🙄 )
May 4, 2022 at 9:34 AM Post #2,617 of 2,891
Kiats
Thanks!
Knock yourself out! There will be a difference for sure. If I recall correctly, the consensus on the Chinese forum is that it’s much better from internal memory. :)
May 4, 2022 at 9:38 AM Post #2,618 of 2,891
NaittsirK
Croatia
I have a Micron SD card and already its audibly more dynamic then via samsung one.
But I think ECC memory has no parallel :)
May 4, 2022 at 9:43 AM Post #2,619 of 2,891
bluestorm1992
Virginia
Thanks!
The internal storage is 64GB iirc. I have been loading some of my favorite albums to the internal storage for a better performance.
I don’t know about the sound differences between different SD cards, but to me it makes sense that there will be a difference between internal storage vs. SD card. The processing from internal storage should be the most direct and hence subject to less loss during signal/information transmission.
May 6, 2022 at 2:07 PM Post #2,620 of 2,891
NaittsirK
Croatia
I just got the p6pro , and notifed that changing any eq preset from normal drastically raises volume? Is this normal?
May 8, 2022 at 9:29 AM Post #2,622 of 2,891
Kiats
Decided to give the Sound Style for the Trailii a run out with the AE. It has been a while since I’ve given the Bird a run out. With the arrival of the Sony 1AM2 and 1ZM2, as well as the MDR-Z1R, it has been kept under wraps a bit. :)
May 8, 2022 at 9:35 AM Post #2,623 of 2,891
NaittsirK
Croatia
Savage flex :)
How do you find the 1zm2 against the LP AE ?
May 8, 2022 at 10:28 AM Post #2,624 of 2,891
NaittsirK
Croatia
New firmware is up !
🔥#LUXURY & #PRECISION ~ #R2R DAP系列新固件發佈 ~ #Sony #Z1R新特調/電量顯示/無損更相容‼】
💪L&P R-2R DAP系列全新固件發佈
時隔4個月,L&P 內置工業級R-2R晶片的LP6系列與全分立R-2R P6系列正式版固件迎來更新!
姍姍來遲的「Z1R特調」
本次固件優化的重頭戲是SONY小Z1R的特調。這款兩圈一鐵的索尼旗艦IEM素質優異、潛力頗大,其相對刺激的風格與柔中帶剛的R-2R機型頗為契合,因此很受L&P 用戶喜愛。在幾位Z1R用戶的回饋下,我們在今年的第一季度著力給其做調音優化。
這是最新內測版本的燒友回饋。由於調音是一個「科學設計」+「主觀感受」雙重疊加的過程,我們也一直遵循「回饋改進再回饋再改進」的迴圈。目前LP6系列和P6系列已實現HD800、大烏托邦、FW10000、朱鸝、IE900等耳機的優化配置,適配任何一款耳機,一般至少在2-3個月,慢慢調和改很磨人,最終還是希望打磨出最符合大多數用家喜好的調音。
重新優化的「電量顯示」
要想聲音好,類比部分功耗勢必會高。LP6系列採用了分體桌上型電腦思路的多路獨立供電架構以及DAC伺服電源。
這是LP6開發過程中5個主要PCB版本,其中為了伺服電源優化、越分越細的供電等設計,必須把側按鍵從主PCB板上移開,以給類比電路騰出寶貴空間。經過內部結構方案多次重大調整,完全做好供電的LP6終於達到了極低失真兼可驅動大耳的高功率。為控制機身體積和重量,我們在權衡之下採用了4800mAh鋰電供電,續航時間相較L&P 下級型號會相對短一些。原先LP6的電量顯示並不准,因此會有部分使用者出現續航焦慮。在經過兩輪內測之後,我們重新優化的電量顯示可以大幅緩解這一問題。
低音量「響度躍遷」更平滑
這是P6音量、推力響度對照圖示。可以看到,音量55以下時,每檔音量變化是按照0.5到0.8分貝來調整,而在55音量以上檔位元時,每格音量變化高達2分貝。傳統音量系統沒有針對便攜塞子優化,因此實際使用時可能對大耳機來說每格音量變化太小,對耳塞來說每格變化又太大。而P6的音量調節在大部分情況下推耳塞都會聽來「過渡平滑」。這次優化的主要是在8-9格之間音量差相對過大的問題。
P6系列是純硬體音量控制,檔位元要提前算好並固定,由電阻網路和開關組成,而這個衰減網路設計時每微調其中一個電阻值,所有檔位元參數都會變動,需要重新計算和驗證,因此會花費不少功夫。關於P系列電位器的設計優勢,可參考《HIFI設備中的重頭戲,音量模組知識科普》一文。
總結本次兩大系列固件更新明細:
💥LP6系列新固件特性
① 支援電量顯示(注:更新固件後第一次使用電量顯示會不准,請充滿電後放電乾淨,以免影響後續體驗);
② 增加Sony IER-Z1R耳塞優化配置;
③ 解決一些相容性問題。
💥P6系列新固件特性
① 增加Sony IER-Z1R耳塞優化配置;
② 優化低音量尤其是音量8和9之間的聽感體驗;
③ 解決某些1TB TF卡的死機問題;
④ 解決某些DSD256音源的額外雜訊問題;
⑤ 解決某些FLAC文件的相容性問題。
💥此次發佈L&P R-2R DAP 系列固件對應具體型號為:
P6、P6 PRO、P6 PRO灰曜石
LP6 黃金版、白金版
LP6 TI、LP6TI 七周年
***以上七款型號固件不通用,需對照指定機型刷機。
L&P R-2R DAP 系列固件: https://bit.ly/3kMfFmm
If any one can translate that would be great as google translate introduces more confusion. 😑
May 8, 2022 at 10:28 AM Post #2,625 of 2,891
Kiats
Savage flex :)
Hmmm.. someone just asked me earlier today. Well, the LP AE is very natural, very organic and shockingly life like. At the same time, absolutely black background and so you hear all the details. I would say it is the best DAP around right now. If we only consider sound quality. No digital glare and consequent fatigue from the AE.
The Sony 1ZM2 is a different creature. It represents the Sony house sound: a bit on the warm side, unapologetically musical, great soundstage, sparkle and all.
Both are very different but at the top of their own game. Do I see either pushing the other out the door? The answer in short is no. :)
