Inspire IHA-1 tube headphone amp
post-13523959
Post #271 of 323
Xcalibur255
The volume pot is out of the circuit completely when it's turned all the way up, so if you prefer to manage volume somewhere else in the signal chain there's nothing wrong with doing this.
Reactions: Admiral Kolchak
post-13525226
Post #272 of 323
DelsFan
Tennersee
Tennersee
Thanks, I guess my question is: With the volume pot out of the circuit, isn't the volume by default at "full" then? And, as long as my DAC has a volume control, is this any big deal? I assume these aren't like a guitar tube amp, where the more volume = the more distortion. Does the IHA-1 behave any differently at full volume? More distortion? Tubes last less long? Etc. Or is a headphone amp a completely different design (as I expect) than a guitar amp.
post-13525807
Post #273 of 323
Xcalibur255
There is no easy way to fully answer your question to be honest but the short version is no. Distortion isn't connected to signal attenuation in the way you're thinking. The amp isn't running "wide open" amplifying as much as it can just because the volume pot is all the way up in this particular scenario. The relationship in the circuit is more complex than that. Now if you had nothing else upstream attenuating the volume it would be a different story.
There's no problem at all with maxing out the volume pot and using your DAC to control volume, it won't cause more distortion. The only tangible difference is that you've removed a resistor from the signal path that would otherwise be there, so if you have keen ears you'll actually notice a subtle improvement in resolution assuming the volume control in your DAC is lossless.
post-13651906
Post #274 of 323
Aornic
Member of the Trade: Acorn Audio
London, U.K.
London, U.K.
Website
www.acornaudio.co.uk
I just got the amp yesterday and it's been hard to pry myself away from my desk since. Current tube sets are:
1) Raytheon 6SN7 (stock)
2) JJ Electronic 5Y3S (stock)
3) Ken Rad 6SN7GT
4) Tung Sol 6SN7GT
5) RCA 7n7 into a 6SN7 converter
3-5 I've been using with my Feliks Audio Elise, an OTL.
I'm very impressed with this amplifier. It has an effortless presentation of detail, and it reaches far and brings so much to my attention. It has transformed my listening experience with my Focal Utopia + Schiit Gungnir Multbit considerably.
I have these in the mail currently, looking forward to them.
The only issue I seem to be having is with using the pre-amp outs with my powered Focal Alpha 50 studio monitors. Seems I'm getting strong feedback/hum because of a ground loop. I had been using the balanced pre-outs of my Audio-GD NFB-28 till now without an issue.
And to clarify, I opted for the pre-outs and Lundahl transformer upgrades. This amp deserves more attention and I look forward to reviewing it comprehensively.
P.S: I also filmed an unboxing, but I'm not very proud of it due to how long it took me to unwrap the thing. I appreciate the amount of protection though.
post-13665203
Post #275 of 323
Rossliew
Can anyone advise what is the safe operating parameters for the amp in terms of current/voltage draw?
Am thinking of other types of rectifier tubes may be used safely.
For example 4 volt tubes with the appropriate adapter.
post-13668434
Post #276 of 323
Xcalibur255
I answered you over on Glenn's thread but I'll recap here. The transformer tap for the rectifier is 5V with a capacity of 3A. There is some overhead tolerance built in and Dennis has told me you can go a little bit above 3.0A without getting into trouble, but I would not push my luck in this department. 4 amp rectifier tubes are definitely off limits, the tranny would get too hot.
post-13668891
Post #277 of 323
Levanter
3) Ken Rad 6SN7GT
4) Tung Sol 6SN7GT
Interested in your impressions on the NFB28 vs iHA-1 vs Feliks Elise. But I'm using HD800S & 650, so not sure if it'll be relevant with what you are using though.
post-13773127
Post #280 of 323
Aornic
London, U.K.
London, U.K.
Website
@Aornic did you ever get a chance to try the Mullard rectifier? I'm curious what you found.
Hi there. I compared a reissue with an old black Base in this comparison video and I have a metal base on its way to me currently that I'll compare to them later.
post-13778952
Post #281 of 323
DaveUpton
post-13779297
Post #282 of 323
Aornic
London, U.K.
London, U.K.
Website
post-13856562
Post #284 of 323
EDWARIS
is it right that this amp is not good for any iems?
post-13856580
Post #285 of 323
Website
www.moon-audio.com
Moon Audio Stay updated on Moon Audio at their sponsor page on Head-Fi.
https://www.facebook.com/MoonAudio/ https://twitter.com/MoonAudio https://instagram.com/moonaudio https://www.moon-audio.com/
