Increasing max volume on ipod nano 2G
Dec 24, 2007 at 10:21 PM Thread Starter Post #1 of 7
Slovenc
Hi
is there any way to increase max volume on ipod nano 2G, bought in uk?
I'm using Creative EP-630 earphones and they are kind of alright just a bit too quiet... Is there any way to make the music sound louder?
Thanks a lot for your help!
Happy Christams!
Dec 24, 2007 at 10:23 PM Post #2 of 7
This application works for my 1G iPod nano. Might work with the 2G nano as well.
goPod
Dec 24, 2007 at 10:47 PM Post #3 of 7
Thanks for your reply!
it doesn't work for me :S
It says "iPod not detected"
Do you know any other solution to make it work or perhaps sth else that i should try?
thanks again!
Dec 24, 2007 at 10:54 PM Post #4 of 7
I have the same model and I never found an app to do what you'd like.
Dec 24, 2007 at 11:06 PM Post #6 of 7
At least it was worth a try...
I don't own a 2G nano, and don't know of any suitable applications. Except for GoPod, which sadly don't work for the 2G nano
