DonChuy
- May 29, 2015
@mrchrisg Thank you
I'm using the same in small and they work great for me. I also use them on pretty much all my IEM's that they work with.I'm enjoying my Zeniths with KZ starlines but had to go down one size to medium. I usually use large on most iems
I went for the Audiophiles, as mentioned by @Jackpot77 . Looking at the photos these appear to have a premium quality foam.
https://www.flareaudio.com/products/audiophile-replacement-earfoams
Click the "size guide" link as that's important to compare against tips that fit you. I went for large from as these are the same size as the large tips (13mm width) as the large tips that come with the IMR Zenith.
Oh and I ordered from Amazon UK:
https://www.amazon.co.uk/dp/B07N12K4BC/ref=pe_3187911_185740111_TE_item
Long story short, I don't think I will be searching for another set of IEM's after this... That is unless Bob delivers something crazy or better yet *fingers crossed* creates an over ear set of cans I can appreciate.
Ouch. I was waiting for this to pop up. I'm honestly sorry you got stuck like that though @HungryPanda. I'm all good with IMR staying with just IEMs but I am curious about their email this morning that ended with "...future products and boy is there some seriously cool stuff coming!"
Whaaaaaaaaat! Perhaps they will blow the r1z's out the waterPlanar IEM's are next up.... I'm terrible at keeping secrets.
To he honest I would be happy with the current driver set up but in a semi custom style acrylic housing. Like the IT04 for example.Planar IEM's are next up.... I'm terrible at keeping secrets.
