I forgot to remind IEM owners that they need to change the polarity (+/-), inside the IEM you need to turn the socket 180 degrees. This needs to be done only for those who use third-party cables, and not the supplied IMR cables.
The fact is that the IMR uses reverse polarity.
When you turn the socket inside the IEM, the bass and overall sound will be correct and will sound as it should.
