Improves SQ more: Better DAC or Amp power?
Sep 4, 2009 at 4:07 AM Thread Starter Post #1 of 2
Zertman
I am looking for a DAC with a built-in amp, to power my Sennheiser HD265 (150ohm) from my Laptop. I want to improve my SQ and I have kinda narrowed my choices down to is: Hifiman EF2($185) or iBasso D10 Cobra($275).
What I have read about the EF2 from HeadphoneAddict is it has a high power amp section but just ok DAC section.
HPA basically says the opposite about the D10. The DAC is great but the amp section is a little weak. I like how it has a digital coax in, is using that better than USB?
So what improves sound quality from a PC more if you have high impedence cans like my 150ohm HD265s, a Better DAC or more amp power?
Or more specifically: Which (d10 or EF2) would be a bigger improvement in sound quality for my HD265s using a Dell M1710 Laptop?
Is there any better DAC/amps for my budget (~$250)? Since it would be for my home setup, I would rather it to be AC powered so I don't have to worry about batteries dying or replacing down the road.
Thanks.
Sep 4, 2009 at 5:26 AM Post #2 of 2
taso89
Either of those will be a huge upgrade from the laptop onboard audio. Those aren't VERY high-impedance cans, so I'd say keep the amp secondary and primarily upgrade your source. So I would pick the one with the better DAC, trade off on the amp which you could always get later on.
