gortsby
- Nov 12, 2002
Have been a reader (we call it 'CD-ROM' in my place) here for a while. Have learnt a lot of things and bought a Grado 60 since then. Thank you all.
Have been ordering a portable META42 and get recommended to use 9.6V Plainview battery. Can only locate rechargeable 9V battery with voltage of 8.4V in the place I am.
My question is: how much will the performance of the amp be affected by the difference in 9.6V vs. 8.4V of the battery?
If the difference is really material, have to consider buying the 9.6V one from the net and get a transformer to step down power supply fm 220V to 110V.
