Just got home from my walk and noticed the little rubber selector on the IEMatch is missing
A bit strange seeing as the unit is only about 2-3 weeks old, and I was using the supplied feet + silicon mat between it, and my Samsung s8+. .. Not to worry though as I never use IEM's, as my daily drivers are the TH-900's, which I have to say pair beautifully with this iFi !!
Flashed to 5.2B firmware as well which seems to run nice, and not drain my phone.. Thanks
@iFi audio !!
I really am loving the iDSD BL .. oodles of power, amazing resolution and just performs exceptionally.
For the OTG people, does anyone have a reccomended android EQ app I can use with Tidal ? I'm using Neutron for locally stored files, but would love to be able to have a strong EQ app for Tidal.
BTW, a friend is going to 3D print me a Samsung s8+ case with additions to mount the iFi into, so I won't have the straps covering the screen anymore, that should be quite neat, the plan is to run the straps behind the phone with slits in the casing for it somehow .. planning that this weekend
Minor note regarding the design .. and it really is an insanely tiny thing, is that when the selector is on 'preamplifier' , its not flush at the top position and appears to be more centered , whereas in 'Direct' mode, the selector is firmly at the bottom, if that makes sense
A good comparison is the Polarity selector, when + of - are selected, the rubber selector is clearly at the edge of is position. .. excuse my poor explanation!
