roamling
- Nov 17, 2008
thanks Dadracer, much appreciated. You certainly got my interest here.
You are entirely welcome and just happy to help. I was going to put up a post last night but it was late when I got home and then I saw your message this morning so I thought that was a good time to break cover!
I don't know if you have an iUSB power already but I am thinking that you are getting most of the reduced noise and jitter stuff which the iUSB3 delivers (well ok not the 3.0 compatibility) in the iP2. Which for me is cool as I have an older laptop with no usb 3.0 ports anyhow.
I've just been looking at the image of the iPurifier 2 with the USB A connector. I'm certain that if you make use of the phono/rca outs on the back of the iDSD micro then it ain't gonna fit as well. The adapter that comes with the iDSD to enable connecting a normal USB cable is flush against my rca cables. The iPurifier 2 is wider than that adapter looking at the image of it.
I've just taken a close look at it and I think it will fit just fine with all normal RCA plugs.
I am running my iDSD from a Vortexbox, which in itself is a computer with a Linux operating system and a harddrive storing my music files, so I am pretty sure there is loads of USB noise coming from the USB port. I was also considering changing the blue stock USB cable but until know I was reluctant to use the supplied adapter. At least with the new iPurifier with the USB A plug I could bridge that gap with an added benefit of USB noise reduction.
I'd like to thank you guys on this forum for drawing my attention to the iPurifier2. Mine arrived a couple of days ago, and I've been listening to it over the weekend. And yeah, it really does work! In fact surprisingly so. I didn't know what to expect, and was prepared for it making no discernible difference. But straight from the box my immediate impression was the sound had a kind of crystalline quality - I guess due to the lower noise floor.
After a few hours - wow! Most things are improved, especially the bass, but also the tone characteristics of instruments and voices - more natural and believable. The soundstage isn't any wider and perhaps only a tad deeper, but the real gain is definition and resolution - you can hear the side and back walls of the recording venue very clearly and how the musicians are placed within them.
I'm using a Mac Mini with an AQ carbon connected to a Chord 2Qute. It just shows how much crap there must be on the USB from a computer being pumped straight into your DAC. I did try the Jitterbug a few months back, but this gizmo is far more effective. I was considering powered options like the Wyrd or the Regen, but this thing has got to be the best bang-for-buck USB fixer.
I'm sure it will and you'd have to hope they would check on that! I am so happy that I will finally be able to bin that nasty plastic 5 pence USB adaptor. It has always annoyed me given the quality of all the other plugs that I have. I even asked ifi Audio to make a Gemini cable with a USB A plug!!!!
Here's a picture of the rear of my iDSD Micro currently. I wouldn't say the RCA connectors on my cables are particularly large or oversized. Just normal size for a fairly decent cable. With the i-fi supplied adapter being smaller than the iPurifier2. There is no way a iPurifier2 is going to fit directly in the USB port using the RCA outs.
