iFi iDSD Micro DSD512 / PCM768 DAC and Headphone Amp. Impressions, Reviews and Comments.
Jan 10, 2021 at 6:00 PM Post #8,956 of 9,047
I already opened, but ifi is charging me 165 gbp to fix this Changing the pcb, besides weeks of waiting and two way International shipping ... but i don't think it worth and i think by changing this switch it will be allright with a fair cost and quickly.
Can you please open up a ticket at our support platform here?
https://support.ifi-audio.com
Thanks!
I a
Jan 11, 2021 at 6:45 AM Post #8,957 of 9,047
Hey, if you can change this switch on your own, by all means please do so! :)
https://www.facebook.com/iFiAudio/ https://twitter.com/ifiaudio https://www.instagram.com/ifiaudio/ https://ifi-audio.com/ https://www.youtube.com/@iFiaudiochannel comms@ifi-audio.com
Jan 11, 2021 at 8:35 AM Post #8,959 of 9,047
Sure. I only wanna know where can i buy it over the internet. I couldn't find.
That's understandable. I'll ask what type of a switch it is and I'll let you know IF I'm allowed to. If I am, I'll get back to you :)
Jan 11, 2021 at 4:10 PM Post #8,962 of 9,047
Mine also had this issue, iem switch was causing imbalanced sound, until I figured it out I thought it is definitely broken. Moving it a bit fixes the issue but it was annoying for a while.
Yeah... i had to pull out the plastic cap and open to clean using a contact cleaner can. When i moved the micro idsd over my desk, sometimes the iematch switch also moved, causing distortion and imbalance.
Jan 12, 2021 at 1:04 PM Post #8,963 of 9,047
Larger switches didn't make it because of how packed the product is inside, but I'll pass on this feedback to our R&D.
Jan 15, 2021 at 10:18 PM Post #8,964 of 9,047
I am having sudden issues with my Micro DSD unit. I upgraded it to 5.3 firmware and when I went into Tidal it said it had exclusive access to MQA (though still no purple light) but the volume is disabled. I installed the latest drivers as well and that is set to Max volume. The problem is the sound is barely audible to my Beyer T1's with the volume at 80% in Tidal or Spotify. The music sounds mostly OK but does sound disorted at times as well. I am unsure what I have changed that I caused this. The output in Windows is set to IFI by AMR HD+ and USB.
In the Windows Sound Control Panel I have the sound set to 32Bit 192K but I have tried at 24bit 192K.
I just tried this on my phone connected via USB-C as wel! It's the same.
What can I check?
Jan 16, 2021 at 5:04 PM Post #8,965 of 9,047
What can I check?
Is it normal if you're not using Tidal/Spotify? Can you please check?
Jan 16, 2021 at 5:43 PM Post #8,966 of 9,047
Connected via USB to my laptop even youtube is pretty quiet.
Is it recommended to use the drivers from the IFI website or just use Windows 10 built in drivers? I assume I can't use the IFI Control Panel with the built in drivers? Seems like it's not the drivers though as it's quiet attached to my phone as well.
Jan 16, 2021 at 10:06 PM Post #8,967 of 9,047
Did you check the ieMatch switch? This switch is causing me trouble because it doesn't sets firmly in one position. And inside the unity there is a plastic cover over the switch, wich can obstruc its path, preventing you to disable it.
Jan 17, 2021 at 6:04 AM Post #8,969 of 9,047
