mandrake50
- Aug 13, 2007
Headphone sensitivity is fixed. Meaning that the ratio of SPL to power input never changes. At the same volume level you will have to have the same exact power going into the headphone. The volume control position is not relevant. Changing the position for the same SPL does not change the power out.
But if you are running at 10 to 11 o'clock, for me that is pretty ideal. You have enough of the travel to get past any low level channel imbalance and still have plenty of adjustment on the high end available.
If you can't hear any difference, I would suggest that you just pick one and don't worry.
