Jefecesti
What input/output is on the right side on the volyme knob?
I think it is the IR for the remote.What input/output is on the right side on the volyme knob?
Should it be a hole?I think it is the IR for the remote.
No, it should be a port with a glass or plastic disc covering the hole, to keep dust/dirt out.Should it be a hole?
Perfect. Thank you.The back of the remote details what battery you need (CR2025). Here is a pic for your use. Positive toward the back side of the remote as pictured. (PS. I don't think you could shoe-horn a CR2032 in there.)
Forget your calculations and forget impedances. You are massively overthinking this (are you an engineer?).I've currently added a Cayin HA-300MK2 tube amp to my Pro iDSD Sig. + Pro iCAN Sig. chain which (now) serve as my DAC and preamp, respectively, but am struggling to find some specs on my iDSD and iCAN to be able to set the volume knob on my iCAN to output the right voltage to the Cayin amp and get the best out of the whole chain. I'd appreciate if you guys could let me know if you have any of those missing values, or if you can offer any other advice/info that may be helpful.
The following is the conditions of my setup and what is known to me:
To keep it simple, I tried to calculate the output voltage of iCAN using the following formula, but I have made a number of assumptions and simplifications as you may read in the text above:
- Cayin amp input voltage and sensitivity: 400 mV, 50 kΩ
- iDSD nominal max output voltage (XLR): 4.6 V (not sure whether this value is for 0dB gain on iDSD, i.e., does the gain setting have any impact on the DAC (line-out) output or it's only impacting the headphone amp output? It's worth noting that the gain setting on iCAN is not only for the headphone output but also for line-out).
- iCAN nominal max output voltage: <23 V (@600Ω). On iFi's website (FAQ page), 20V is mentioned for XLR line-out (max undistorted output as a combination of volume control and gain setting). I assume this relates to the gain setting of 18 dB, as theoretically with the lowest one (0 dB) the max output voltage shouldn't exceed 4.6 V. Or am I wrong?
- iDSD output impedance?
- iCAN input impedance and sensitivity?
- iCAN output impedance: seems to be 3.2 Ω according to a 3rd party measurement, but no official data could be found from iFi.
Vout = (Vin × 10^(dB/20)) / (1 + (Zout/Zin))
Where:
There comes a few more questions:
- Vin is the max output voltage the iDSD
- dB is the gain on iCAN (in dB)
- Zout is the output impedance of the iCAN
- Zin is the input impedance of the amplifier
- Vout is the output voltage of iCAN to the Cayin amp
I currently keep the volume knob on the iCAN at about 10% to output a max. nominal voltage of 0.46 V. In case my assumptions are incorrect and the worst case scenario comes into picture, iCAN will output a bit less than 2 V which is not crazy high either. But it's worth mentioning that initially I used to keep the volume knob at ~25%-30% and all my headphones sounded good without any noticeable issues. If my assumptions are right, at 25% (9 o'clock) iCAN should output about 1.15 V, which is about 3 times higher than input sensitivity of the Cayin amp, an advised range within the community and a safe ratio to work with. However, when increasing to higher volumes (say 50% or higher) I could hear distortion and obviously the increments on the Cayin amps volume were much bigger per step. Similarly, when I connected the Cayin amp to iDSD line-out directly (fixed, nominal 4.6 V) I had to decrease the volume on my Cayin amp to very very low (probably 2-3 steps, 7-8 o'clock, only was already loud on a 300Ω high impedance headphone), as each step was a huge increase in volume. Accordingly, excluding iCAN from the chain won't solve the problem because then I have to switch to Variable HiFi mode and play with the volume knob on iDSD to get to the right output voltage.
- Should I take the input sensitivity and impedance of iCAN into account when calculating Vin for the formula above, or should I keep it simple? (as I do not have the values).
- Can I assume that the volume knob on iCAN increases the output voltage to the Cayin amp in a rather linear way (say, 12 o'clock meaning 50% of max output voltage?
- etc.
Also, worth mentioning that I use the XLR outputs on both iDSD and iCAN and, therefore, my calculations all consider the related values and specs.
You're right. I know I'm overthinking it. And yes, unfortunately , I'm an engineer (not audio) with a PhD in Science and Engineering. So, I guess I can't help overthinking it until solving the riddle (at least for myself; it's a hobby in the end). It sucks to be that and also an audiophile, right?Forget your calculations and forget impedances. You are massively overthinking this (are you an engineer?).
The input sensitivity of the Cayin is merely the input you need in order to get maximum output when the volume control is at maximum. Higher inputs are fine. Certainly 2.3V (4.6V balanced) shouldn't trouble it at all. Just turn the volume down.
From the iDSD you need 0dB gain since 2.3V (4.6V) is already enough.
From the iCAN you need 0dB gain for the same reason. Turn the iCAN volume to maximum.
If this gives you too small a volume control range on the Cayin before it is too loud, then reduce the volume on the iCAN until a reasonable range is achieved.
If the volume control on the Cayin is still too coarse then use the volume control on the iCAN for finer adjustments.
Don't turn the iCAN down any more than you have to as this will decrease signal to noise ratio (the Cayin will be more noticeably amplifying the noise floor of the iCAN).
It does say in the Pro iDSD manual that it will output 2.3V single ended or 4.6V balanced when the output selector is set to 'HiFi Fixed' on the back panel so you are good to go.You're right. I know I'm overthinking it. And yes, unfortunately , I'm an engineer (not audio) with a PhD in Science and Engineering. So, I guess I can't help overthinking it until solving the riddle (at least for myself; it's hobby in the end). It sucks to be that and also an audiophile, right?
I just do not want to exceed the range on the iCAN voltage output where my Cayin amp is overdriven unnecessarily, i.e. know my technically-sound and safe range to play with when playing with the volume knobs as you also indicated.
Keeping it very simple, if I can have confirmation from iFi that the input voltage of iCAN is 4.6 V by default (no gain stage engaged) when iDSD outputs 4.6 V the rest of the calculation is easy for me. Maybe I should send them an email.
Then I can indeed follow your advise in the safe volume range and even (one-step further with the variable output on the iDSD and its volume knob) find the optimal range on them all according to my listening taste. I don't want to just rely on my ears on that but take the right technical approach to get the best out of the whole chain.
Thank you indeed though for your engagement in the discussion. No one knows everything, every advice is something new to learn from Would be glad to hear more from you and your experience, certainly.
Stay updated on iFi audio at their sponsor profile on Head-Fi.
