I made a 4.4mm to 2 x RCA, the negatives not used at all, works a treat Diablo to single ended amp, tried it on a Schiit Heresy, perfect.
Cables I have seen advertised indicate an entirely different wiring set up which is not suitable in this application, the negatives will be grounded and the ground wont be connected at all.
I have two different 4.4mm male to 3.5mm female balanced to single ended adapters coming which should achieve the same thing using a standard 3.5mm to 2 x RCA cable, I’ll report back.
Second photo added, Diablo into Heresy with the cable below. No I am not suggesting using a $1,000 DAC with a $100 amp, the Heresy was just a convenient way to demonstrate it with everything in one picture.
