iFi audio xDSD- The Official Thread
post-15476000
Post #1,981 of 2,006
iFi audio
Sponsor: iFi Audio
Website
ifi-audio.com
Reactions: RockStar2005
post-15482168
Post #1,983 of 2,006
shimigg
You could actually connect the OTG USB Type C cable to the blue USB cable that is supplied together with the xDSD. I use this setup to amp up my car stereo and it works perfectly.
I'm just looking to buy another cable like the blue one , the extension USB 3 cable , but cables I bought from Amazon are not working with my phone , only the original ifi one that came in the box
post-15511641
Post #1,985 of 2,006
hifi80sman
CA, USA
CA, USA
Has anyone compared the fiio btr5 with these? Which are better for the price?
PRICE: I had the FiiO BTR5, which now due to supply & demand, is going for anywhere from $159 to $199 after an original price around $100 (I got mine for $119 w/ same-day shipping, saw listings from $99 to $129).
SIZE: They are different form factors, with the BTR5 essentially the size of a typical dongle, while the xDSD is 60% the size of a normal smartphone and about 75% thicker. If you NEED the smaller form factor, the BTR5 is the way to go.
WIRELESS: If you NEED aptX HD & LDAC, BTR5 again is your choice. It also has BT 5.0, a mic for calls, and can pair to 2 devices simultaneously. The xDSD tops out at aptX and does not have a mic. If you're primarily using Spotify, then traditional aptX which the xDSD has, is sufficient.
CONNECTION: BTR5 has both 3.5mm unbalanced & 2.5mm balanced, while the xDSD has a single 3.5mm that can handle both balanced and unbalanced. S-Balanced Tech seems interesting, as it separates the ground from a single-ended unbalanced connection. Theoretically, the xDSD will give you better performance with a single-ended 3.5mm unbalanced connection. So far, my experience has been very positive. There is clearly more power to drive with the xDSD, resulting in improved dynamics.
APP: The BTR5 has an App, but it's only average at best. It's nothing like the App that comes with the Radsone ES100, which is stellar. xDSD doesn't have an App.
SOUND: SQ wise, I give the nod to the xDSD. For me, I prefer the Burr-Brown DAC used in the xDSD over the EES SABRE (ES9218P) in the BTR5. The overall soundscape just feels more lush, and while the BTR5 is very clean/clear, I get the impression it's "missing" something. Don't get me wrong, the BTR5 still sounds great, but I can appreciate the sound, especially vocals, more with the xDSD. The xDSD also does a better job playing with full-sized headphones, giving me an overall more immersive experience vs. the BTR5.
If you don't need the mic and super-mobility, as long as money is not a hindrance, I personally like the xDSD more when it comes to pure audio enjoyment.
post-15511646
Post #1,986 of 2,006
Devodonaldson
San Pedro, California
I own both And use them for different things at different times, but I completely agree with your assessment. I also have a Mojo and a Monolith portable THX DAC/Amp.
post-15512342
Post #1,987 of 2,006
shimigg
Guys, I asked multiple times and no good answer , I connect my xDSD to my Android phone , using the blue USB cable that came in the box and than a USB c otg cable , I tried to find a replacement USB cable like the blue extension that came in the box with xDSD but none work, I ordered some quality ones but none actually work.
Anyone tried a different USB extension cable ?
post-15512845
Post #1,988 of 2,006
Devodonaldson
Shouldn't be an issue. I've used severally different cables to connect xdsd to Android device. What phone are you using? The issue may be in the phone settings, not the cables you are trying to use.
post-15513244
Post #1,990 of 2,006
iFi audio
Sponsor: iFi Audio
Website
ifi-audio.com
Thanks!
:beerchug:
Great guide! Out of curiosity, which cans/IEMs you use with your portable devices?
post-15513566
Post #1,991 of 2,006
hifi80sman
CA, USA
CA, USA
Thanks!
:beerchug:
I use quite a few, mostly in my office, where I need some portability, but not complete on-the-go mobility, hence some larger and open-back selections. I'll give you some of my more recent choices:
Sony MDR-Z7M2
Sony MDR-1AM2
Master & Dynamic MH40 (Alcantara)
HIFIMAN HE4XX
Audio-Technica MSR7b
Sennheiser HD 569
beyerdynamic Custom One
beyerdynamic DT 1770 Pro
post-15528253
Post #1,992 of 2,006
bedlam inside
Sony MDR-Z7M2
Sony MDR-1AM2
HIFIMAN HE4XX
Sennheiser HD 569
I use the xDSD for potable listening and looking to upgreade my cans. Some good choices above. Which ones did you prefer? Thanks.
post-15528298
Post #1,993 of 2,006
iFi audio
Sponsor: iFi Audio
Website
ifi-audio.com
Sony MDR-Z7M2
Sony MDR-1AM2
HIFIMAN HE4XX
Sennheiser HD 569
Wow, that's a lot of cans! What's your primary? HE4XX?
post-15528647
Post #1,994 of 2,006
hifi80sman
CA, USA
CA, USA
Primary right now are the Sony MDR-Z7M2 & Audio-Technica MSR7b. Different flavors for different moods. :)
Noise is a factor when using the HE4XX, so typically I use those in the late evening when things have calmed down.
post-15528653
Post #1,995 of 2,006
hifi80sman
CA, USA
CA, USA
For detail and clarity, the Audio-Technica MSR7b. Simply relaxing, Sony MDR-Z7M2. More aggressive sound, beyerdynamic DT 1770 Pro.
Really depends the type of music you listen to and what kind of sound signature you enjoy.
