- Mar 20, 2013
I am very pleased with my xDSD and I would not want any prospective buyers to be put off.
Thanks! Enjoy!
Stay updated on iFi audio at their sponsor profile on Head-Fi.
I noticed that the xDSD keeps blinking white on the battery LED even though it has been on the charger for about 3 hours. Will the charge actually reach 100% and the LED will stop to blink? Or will it just goes on blinking forever as long as the charging cable is plugged in and turned on?
Sorry to ask... I tried searching more info on this but could not get any conclusive answers.... Does anyone has the same issue as mine? Thanks!
Hi thanks for the reply.I've never noticed mine doing that. Is it turned on when doing this? Did you try a different PSU and lead?
I had mine turned off and plugged to a 5V, 1A handphone charger when charging.
Meaning yours will stop blinking completely when fully charged? What type of PSU do you use when charging?
Yes that's how mine works, I checked again yesterday when it was fully charged. I have a 4 port Anker USB charger that is capable of 2.4 amps per port, probably overkill for the xDSD and an Amazon basics micro USB cable if it helps.
xDSD stays a bit warm while its plugged in so I always unplug it as soon as the light goes out. I would try a different charger if you are worried about the blinking
I'm using these to connect them.Can someone post a cable to connect the xdsd to an Android device with USB c on the phone side , the cable has to be long enough so I can use the phone , also , I have ordered a few USB 3 extension cables and none work when connecting those to Android with USB cable , a link to a working one like the one that came in the package , the blue one , thanks !
These are OTG USB Type C cables.
The ifi one is more flexible if you want to stack the device together with your phone so that you could multitask on it while using.
The one on the left is from Lenovo which I ordered from Taobao. It is more rigid.
Both of them yields the same SQ.
and for Android devices, to fully decode MQA u shall also need this app installed:
USB Audio Player PRO (UAPP)
All good but it doesn't let me use my phone , I need a compatible USB extension cable like the blue one that comes with xdsd , no other extension cable works
You could actually connect the OTG USB Type C cable to the blue USB cable that is supplied together with the xDSD. I use this setup to amp up my car stereo and it works perfectly.All good but it doesn't let me use my phone , I need a compatible USB extension cable like the blue one that comes with xdsd , no other extension cable works
