hamachan
- Jan 14, 2016
I cannot compare micro iDSD BL since I do not have it. Please refer others like Devodonaldson above (he is definitively talking about headphone out, not RCA lineout though). Between iDAC2 and xDSD for lineout comparison (xDSD has fixed lineout mode), I must say iDAC2 is superior to xDSD. I am using iDAC2 with pro iCAN as headphone amp or preamp as well and the sound is great! If you have certain budget and no portable use is intended, that combination is highly recommended.Additionally, where does the original micro iDSD fall in between for the same purposes? I'm looking for the best transportable solution to use with a laptop and relatively efficient headphones and IEMs where the highest power is not a consideration. Furthermore, I aim to use it to feed a home hi-fi setup via the line-out. A laptop feeding USB power to any of the three democratises all the options except maybe in the case of the xDSD which is slightly smaller but for my uses, the slightly smaller size is negligible.
There is no meaning to compare 3.5mm headphone out for iDAC2 because it is DAC, not headphone amp.
