iFi audio xDSD- The Official Thread
post-15065720
Post #1,711 of 1,983
Gamblel254
Where can I see a photo of the Gen2 USB-C xDSD?
It's not on the iFi website?
Both the USB data and the USB power are Type C connections?
Can someone kindly share a photo @iFi audio
Edit: found this in this thread Post #1595
Reactions: RockStar2005
post-15065857
Post #1,712 of 1,983
TooPoorForHiFi
Previously known as MidNighTempest
Earth
Earth
There is a Gen2 coming out? WHEN!?
Any more INFO?
post-15065869
Post #1,713 of 1,983
Joseph Lin
Any more INFO?
The ones I received come with USB C port. The first one does charge but not holding a charge. The 2nd one does not charge at all not even with the original cable. The charging light is off, no idea how much battery capacity left. Both of them have USB C port assuming 2nd generation. Walk away from 2nd gen. I saw both Amazon and Head-Fi have a few reports of not charging as well.
post-15066273
Post #1,714 of 1,983
TooPoorForHiFi
Earth
Earth
Did you order from Amazon US?
post-15066319
Post #1,715 of 1,983
iFi audio
Sponsor: iFi Audio
Website
ifi-audio.com
We're very sorry about this happening to you. Have you tried dropping us a line here: https://support.ifi-audio.com/
You probably tried many different ports/chergers already, but are the ones you used within specs?
post-15066434
Post #1,716 of 1,983
Gus141
New England, USA
New England, USA
I just purchased xDSD and is experiencing very weird symptom that it will pause for a 0.1 second like the buffer is trying to catch up with the data consumed and then it will resume. It makes it almost impossible to listen to music. I tried extra safe mode, it still stutters. I am on the newest firmware 5.3c. Did anyone experience this behavior? Any solution?
Problem 2: I have been charging it for whole day and the battery indicator is still red(very dim). When disconnected from power source, it won't turn on. I never have a device with so many problems. I am thinking of returning it now.
New xDSD user as well (rev 2 w/USB-C) and experienced something like the pause/stutter you describe (it was almost like a pop every 15 to 20 seconds). This only happened after I updated the firmware to 5.3c and only when listening to MQA tracks. I fell back to 5.3 and everything was fine again. I’m sticking to 5.3 because I think the 2 filters sound great (didn’t notice much difference with the GTO filter because it sounded good too) but I like the KHz LED to show the color applicable to the input rather than show the same color for everything except MQA, caused by the upsampling for the GTO filter.
As for the power problem you describe, I have not tried any USB-C chargers but have had no problem using USB-A chargers with the included A-C cable. In fact with a 5v/1.8A charger charging speed was quite fast.
I may go back to 5.3c and do more troubleshooting and see if it’s just certain MQA tracks that skip/pop (e.g., 24/44.1 -> 24/88.2 vs 24/48 -> 24/96). @iFi-Audio, is there any risk going back and forth multiple times on the firmware?
Cheers
Gus
post-15066506
Post #1,717 of 1,983
TooPoorForHiFi
Earth
Earth
Cheers
Gus
May I ask where did you Buy your xDSD?
post-15066605
Post #1,719 of 1,983
Gus141
New England, USA
New England, USA
In an on-line review by Hi-Fi News, on the ‘Sidebar’ part of the article ‘Listen or Measure’
[this link
https://www.hifinews.com/content/ifi-audio-pro-idsd-headphone-ampdac-sidebar-listen-or-measure
or this link for a PDF
https://ifi-audio.com/wp-content/uploads/2018/06/xDSD_HiFiNewsReviewOutstaning.low-res.pdf ]
the author says about the filter switch, “iFi Audio has its screen printing reversed around this little switch, so ‘Listen’ is ‘Measure’ and vice-versa. So it’ll be interesting to discover which, if any, headphone bloggers can hear the difference!”
Is this true? I was assuming that with pre-5.3c-firmware, Measure was a linear phase fast filter and Listen was a minimum phase slow filter. But if the switch is reversed based on this reviewers measurements, what switch position is the GTO filter mapped to on firmware 5.3c?
post-15066619
Post #1,720 of 1,983
RockStar2005
Chicago Suburbs
Chicago Suburbs
[this link
Wait, WHAT?!! They're reversed-labeled??!! iFi, PLEASE confirm or deny this.
post-15066836
Post #1,721 of 1,983
flyte3333
Previously known as Em2016
Hi all / @iFi audio
What does it mean when the rotary LED is red and also input and kHz LED are both red (all solid red, not flashing) when xDSD is off and only charging at the wall?
This scenario isn’t covered in the manual...
5.3C firmware
post-15066843
Post #1,722 of 1,983
flyte3333
Would be great if @iFi audio can confirm what this is about.
Only taking a guess the reviewer means he looked at his measurements and saw the “listen” filter resulted in linear phase impulse response and the “measure” resulted in the minimum phase response. Which indeed would be backwards.
But it’s hard to know as the reviewer didn’t expand more. But hopefully iFi can clarify.
post-15066853
Post #1,723 of 1,983
Bansaku
Edmonton, AB
Edmonton, AB
Age
41
Hi all / @iFi audio
This is a first for me and have yet to hear about nor experience this scenario. TBH, all red doesn't sound too good. @iFi audio is going to have a busy day tomorrow replying. :stuck_out_tongue_closed_eyes:
Reactions: flyte3333
post-15068282
Post #1,724 of 1,983
iFi audio
Sponsor: iFi Audio
Website
ifi-audio.com
This would indicate little leakage that keeps the xDSD's circuit running: http://support.ifi-audio.com/kb/faq.php?id=896
Please reach us at our support platform, thanks!
We're ALWAYS busy. Even when we sleep, we work. We're machines, not real people. Bzzt, bzzt.
Reactions: docentore
post-15068290
Post #1,725 of 1,983
iFi audio
Sponsor: iFi Audio
Website
ifi-audio.com
Users Who Are Viewing This Thread (Users: 0, Guests: 3)
