iFi audio xDSD- The Official Thread
May 2, 2019 at 3:21 PM Post #1,562 of 2,505
https://www.facebook.com/iFiAudio/ https://twitter.com/ifiaudio https://www.instagram.com/ifiaudio/ https://ifi-audio.com/ https://www.youtube.com/@iFiaudiochannel comms@ifi-audio.com
May 2, 2019 at 3:30 PM Post #1,563 of 2,505
You also have a very nice site.
Bloom Audio Headphones and Personal Audio with Pitch Perfect Service. Stay updated on Bloom Audio at their sponsor profile on Head-Fi.
https://www.facebook.com/BloomAudioStore https://twitter.com/BloomAudioStore https://www.instagram.com/BloomAudioStore https://bloomaudio.com hello@bloomaudio.com
May 4, 2019 at 7:55 AM Post #1,566 of 2,505
No sorry, actually my question is for the one I posted. This one:
I simply cannot get it to work to see Magenta light for MQA in my Huawei Mate 20 Pro as on the video with just Android and Tidal. What is missing? I have succeeded using the third party app UAPP, but on the video is not used, so what is missing?
Not sure but it's the same with the Oneplus 6. Works with UAPP but the vid has it play through the tidal app.
May 4, 2019 at 2:36 PM Post #1,567 of 2,505
I don’t know if this will address your issue, but if you have updated the firmware on your xDSD to the latest version, the light indicating sampling frequency will always be yellow since all files are upsampled. If you go back one version, then the magenta light turns on with MQA files.
May 5, 2019 at 5:05 PM Post #1,568 of 2,505
Even the GTO firmware goes magenta with MQA.
May 5, 2019 at 9:06 PM Post #1,569 of 2,505
I have my AK240SS connected to the xDSD via the USB input, and when I play an MQA file the sampling light is yellow. I tried several of my MQA files. I recall on the firmware installed at time of purchase that the magenta light did work. When I updated the firmware to the current version and read about the GTO filter, I assumed the new filter was responsible.
My xDSD is two months old.
May 6, 2019 at 4:05 PM Post #1,570 of 2,505
I haven't updated my firmware and I do get Magenta light with UAPP, but, I don't want to use UAPP, it's ugly and I cannot find it simple as Tidal's interface. Tidal is simply intuitive, so I prefer to stick with just Tidal, however, I'm giving up MQA.
As for your case, I suspect is the same thing, maybe if you use UAPP and bit perfect add-on, you may get the Magenta light.
As for the video, I suspect it is cheated unless @iFi audio confirms otherwise.
May 6, 2019 at 6:05 PM Post #1,571 of 2,505
You're not seeing magenta LED due to what's coming out of your phone. Our GTO filter doesn't influence MQA as it can't. As a manufacturer we can't manipulate MQA in any way inside our hardware as this defeats the purpose of MQA.
May 6, 2019 at 6:22 PM Post #1,573 of 2,505
Thank you for your reply. So, I’m not using a phone, but a $3,000 dap as a transport connected to my xDSD via USB. As mentioned before, when I first got the xDSD a couple months ago, it had not been updated to the GTO firmware. When I played MQA files then, the magenta light worked. Now with the GTO firmware installed, with the identical setup so the only change is the firmware, I get yellow with MQA as well as everything else.
May 6, 2019 at 7:15 PM Post #1,574 of 2,505
I know. Maybe is asking too much as it's not an issue of the xDSD. But anyway, the video shows it's possible but not how to achieve it 100% as the steps on the video are not enough. I have the same phone used on the video. I remember you told you was going to ask to the iFi team that did the video but nothing has come out as a proper answer.
May 7, 2019 at 5:31 PM Post #1,575 of 2,505
Folks, Android is Android. At times it gets updated without even noticing its users and we've already seen a bit-perfect stream not bit-perfect any longer after OS update.
The only thing not shown on that MQA vid with Huawei Mate 20 Pro is its MTP mode engaged. Now, several months later it's not MTP any longer but 'Transferring files'. This needs to be turned on and everything else is should be done as shown in our vid.
If there are any questions, you can always shoot us a message here: http://support.ifi-audio.com/
