- Mar 20, 2013
it is not something recommended to use with wet or still damp hair after a shower ...
True
Stay updated on iFi audio at their sponsor profile on Head-Fi.
Can someone please clarify: can this be run by itself or does it need an external amplifier to operate? A video reviewer (YouTube) on this explicitly stated it could just be plugged into the wall and run by itself, and the official documentation indicates it needs an amplifier plugged in to run.
I wonder if the iFi chain pro iCan and pro IESL can drive Focal Jmlab Electra 946 speakers?
Here are the specs of the Focal Electra 946:
@iFi audio
Small question about Pro iESL, I'm a bit curious about the output impandance of the 4-Pin XLR Dynamic Headphone Socket, I can't find it in the techical specifications, is there any reason for this?
Other question, if you would feed the Pro iESL using this DAC https://www.rme-audio.de/downloads/adi2dac_e.pdf using balanced XLR line out, would the 21,5 dBu (10 Volt) sufficient for 580 V Stax Pro Bias output (using the best Impedance Adjustment on Pro iESL in this case)? Is there a possible calculation for this output power?
Maybe the outputs are meant to be used for connecting the AKG K1K through speaker connectors?Might be a stretch, but I'll ask internally about this.
As such, the RME's line outputs at 200 Ohms (Balanced) are not usable, the level is too low as well. This product's headphone out has low enough output impedance, but output levels appear still too low. As a source for iESL, we recommend a headphone amplifier capable of producing 20V into 16 Ohm with < 2 Ohm output impedance, such as the iFi iCAN Pro
Dear greenkiwi
It works with cables that 100% implement the HDMI Standard, as for example detailed here:
http://electronics.howstuffworks.com/hdmi2.htm
Unfortunately, we found that few commercial cables follow this standard. So the issue is not that we stepped outside the standard, but that in many cases the standard is simply not followed.
For any customer needing details for a custom cable to be made, please open a ticket with our support team who will assist in clarifying which exact connections are needed. Here's the link: http://support.ifi-audio.com
Best wishes
iFi audio Team
Someone from Kordz says: "Anyone knows if the Cordz Lux hdmi cable can be used?
Technical Specs:
- 4K Ultra HD video, 1080p60, 3D, HD Audio and High Speed across all lengths
- Solid core conductors ensure highest data speed
- High gauge solid-core OFC (Oxygen free copper) with 12% silver plating
- SureFit™ palladium plated die-cast connector with copper pins
- reduced capacitance and digital jitter for consistently high data rate support
- Copper pins for consistent and reliable signal integrity
- Proprietary B.O.S.S cold solder connection method
- 2kg retention force, fits firmly into HDMI receptacle without falling out
- Ethernet and Audio return channel
- Immortal Lifetime Warranty
