iFi audio Pro iDSD (Official) - NEW Firmware - MQA and more.
Jan 24, 2018 at 7:44 PM Post #16 of 2,185
The question is, though, what happens in years to
Come when the warranty has expired?
According to Terms and Conditions for Warranty;
https://ifi-audio.com/warranty/
The owner is responsible to pay for repairs after the expiry of the warranty period, which is normal for any electric appliances. iFi does not specify the period of the availability of the parts. It means that you may have a chance to repair your old products in future if the part is still available. In contrast, Panasonic guarantees their inventory period of the spare parts after the product is discontinued (5-8 years depending on the product) but you have no chance to repair after that because they throw away the spare parts at the inventory period is expired. I like iFi's vague policy because I will have a chance to use the product longer. Of course, a risk remains in case pro iDSD becomes smash hit in the market greater than iFi expects. :dt880smile:
Jan 27, 2018 at 5:18 PM Post #21 of 2,185
Some verification from Ifi Audio would be appreciated: are the tubes in the Pro iCan and Pro iDSD with the GE5670 pin out, or have they got the 6922 adapters fixed, so other 6922 (or similarly compatible) can be used?
Yes, GE5670 pin out in the Pro series.
https://www.facebook.com/iFiAudio/ https://twitter.com/ifiaudio https://www.instagram.com/ifiaudio/ https://ifi-audio.com/ https://www.youtube.com/@iFiaudiochannel comms@ifi-audio.com
Jan 27, 2018 at 5:27 PM Post #22 of 2,185
Pro iDSD - The easygoing perspective
The enclosure and front panel – part 1/2
Introduction
Our latest and greatest DAC – the Pro iDSD – is just around the corner. We’ve already tackled several technical matters related to this device, and all these are to be found via links in the first post of this thread:
· https://www.head-fi.org/threads/ifi-audio-pro-idsd-the-official-thread.869144/
In short, we’ve explained in our regular fashion why this product is very unique. Since there’s still some time left to the official launch of our upcoming flagship DAC’s, we thought we’d describe in a less techy and more easygoing, newbie-friendly way what our Pro iDSD is all about. First stop is its enclosure’s front, back and - later on - also innards.
The Pro iDSD – what is it exactly?
This machine, in short, is a DAC, also known as a d/a converter and quite commonly as a source. This means that its main purpose is to receive a digital signal either via cable or wirelessly, convert it to its analogue form and then pass it on to devices such as a preamplifier, a stereo power amplifier, a pair of mono amplifiers, a headphone amplifier or directly to various headphones. Yes, all these devices operate in the analogue domain, which leads us on to this statement:
· The Pro iDSD won’t pass digital signals to a different DAC and yes, this is on purpose.
The Pro iDSD was primarily built as a high quality digital to analog converter and this is how it should be used. It’s already function packed as it is and - instead of making it operable as an S/PDIF converter - our goal was to use the space normally reserved for this in a more useful way. Basically, using the Pro iDSD to feed a similar device with a digital signal is a big waste of its potential.
The enclosure
Now, we have all that out of the way, let’s focus on the Pro iDSD’s enclosure. This machine is the same size as the iFi audio Pro iCAN and both products look very similar. The enclosure is made out of aircraft grade aluminium and its main purpose is to dissipate heat from the devices inside as they will get hot when powered on. In order to further improve on this, the chassis has many venting holes on its sides and on top. These align in a pleasantly rounded shape with a magnifying glass with a pair of fabulous vintage JAN GE5670 valves underneath. (Quick note – these class act valves are now reserved ONLY for our Pro series products but that’s another story). Anyway, we reckon that the Pro series chassis looks very cool.
The front panel – LED diode and standby/power switch
Let’s start with the upper left corner. There’s the iFi Pro logo based on a LED diode. Once the Pro iDSD is powered on, this lights up with one of four different colours. Each indicates a different operational status:
· Green: warming up
· White: solid-state mode
· Orange: tube mode
· Red: protection mode
Moving on, there’s a small, flat button in the lower left corner. This turns the product on or puts it in standby mode if you are not shutting it down completely.
The front panel – input selector
Let’s now go a bit to the right. A large and endlessly rotating aluminium knob is next in line. It handles several jobs with its main one being digital input selection. You can cycle through the following options:
· Ethernet/WiFi/Hard Disk/Micro SDHC (Network Bridge/Streamer)
· Host USB
· Coaxial/Optical Digital Input
· XLR Digital Input
· BNC Digital Input
There are also two additional adjustment options available via the input selector:
· Brightness (adjustable via a three second press)
· Polarity (adjustable via a long press)
The front panel – digital filter selector
The smaller knob located a bit to the right from the input selector is the digital filter selector. It enable two things.
The first feature (available via pressing the digital filter selector) is our proprietary DSD remastering. You can choose whether you’d like to have your music:
· Normal – where DSD signals are passed directly to the DAC. For PCM you may choose between a set of digital filters or bit-perfect, unprocessed PCM
· Upconverted to DSD512
· Upconverted to DSD1024
The second feature allows you to cycle through these five different filters on the fly via the rotary action:
1. 'Bit-Perfect' - No digital filtering is applied, one tap
2. 'Bit-Perfect+' - No digital filtering is applied, one tap, SINC roll-off @ HF is corrected
3. 'Minimum Phase' - Minimum filtering, no pre-ringing, minimum post ringing, 32 taps
4. 'Apodising' - Modest filtering, no pre-ringing, modest post ringing, 128 taps
5. 'Transient Aligned' - Max filtering, max pre-ringing, maximum post-ringing, 16,384 taps
Please think of these filters as different flavours. Each trades off frequency response flatness, transient response and suppression of ultrasonic images in a different way. There is no “perfect” filter option, such a thing is not possible, so select the filter that offer the right set of compromises for you.
We’ve already covered in detail how our proprietary digital filtering works in the Pro iDSD. Please take a look here:
· https://www.head-fi.org/threads/ifi-audio-pro-idsd-discussion-thread.702376/page-127
What’s important is that the Pro iDSD is equipped with a FPGA chip that runss on iFi audio’s custom firmware and is responsible for all filters and remasters listed above. It’s worth noting that in this DAC, these operations are hardware based.
Jan 29, 2018 at 5:50 PM Post #24 of 2,185
Are these gonna be stackable without a rack like the iRack? Or am I gonna have to leave them side by side if I don't have a fancy (expensive) rack? It will be hard enough scraping up the cash for this.
Yes, both Pro range products can be stacked. The hotter one should be on top.
Jan 31, 2018 at 5:15 PM Post #27 of 2,185
The enclosure and front panel – part 2/2
The front panel – output section mode
One of the most unique features of our Pro iCAN is its complex output stage based on both transistors AND valves. We’ve developed it to give you the ultimate headphone amplifier and an exceptionally flexible product, which will work with headphones of every sound characteristic there is. Our goal was to create a machine that would be ‘liked’ by every pair of headphones, IEMs and CIEMs out there. We strongly believe we’ve cracked it.
This tech was just too good to be locked away after we used it in the Pro iCAN so, we gave it another whirl in the Pro iDSD. The output stage of this DAC consists of three different circuitries which deliver different outcomes sound wise. You can cycle through these output stage modes:
1. ‘Solid-State' - a purely solid-state J-FETs based circuit of fully-discrete Class A topology.
2. 'Tube' - the J-FET circuitry is switched to an all-valve Class A section based on 2x GE5670 tubes.
3. 'Tube+' - reduces available negative feedback to a minimum. As a result, a greater amount of the tubes natural harmonic distortion is produced (even order harmonics dominate).
Toggling between these three modes can be done without shutting the Pro iDSD off, but there’s a short pause as the circuitry switches over.
The front panel – OLED display
We believe that a product as packed with functionalities as the Pro iDSD deserves to have a brilliant looking, readable, nicely embedded display. OLED was the only answer. Such a display provides a true black colour and looks great. Its purpose is to provide you with all the key playback info you need when using the Pro iDSD.
· Operation mode (PCM/DSD)
· Current sample rate (44kHz, 45MHz etc.)
· Bitperfect/filtering mode
· Base sample rate
· Currently used input
The front panel – headphone outputs and gain section
Even though the Pro iDSD is a above all else a DAC , we wanted to make it as versatile as possible and, in order to do so, we built in a sophisticated headphone amplifier. This circuitry is understandably bested only by the Pro iCAN, our TOTL standalone headphone amplifier. And there’s a very good reason why this is the case.
The circuitry for both the Pro iCAN and Pro IDSD is actually based on classic studio circuitry. It consists of tubes given the hybrid treatment with solid state parts to give them a higher output current. This topology makes for an excellent line or headphone driver. This circuit is actually VERY SIMPLE and minimizes the number of active stages and parts in the signal path. In short, a win-win scenario.
The main differences between the Pro iCAN and the Pro iDSD in this regard is that the Pro iCAN has twice as many output devices, is biased deeply towards class A as it is optimised as a headphone amplifier for all headphones.
Meanwhile, the same circuitry in the Pro iDSD is optimized as a line driver, but has enough output current to drive headphones. Its output power is reduced in the process and the bias is much less towards class A. As a result, the Pro iDSD is not optimised as a headphone amplifier, yet it will still drive most headphones well.
In the Pro iDSD you have several headphone outputs to choose from. Single-ended 6.3mm out is mandatory in devices of this caliber. This socket is also complimented by one 3.5mm (both SE and S-Balanced, just like the same output in our nano iDSD Black Label) and one fully balanced 2.5mm TRRS output. These two are to be found right below the 6.3mm out. To complete the picture, an adjustable gain switch is there too. It allows you to boost the signal by 9 and 18dB or leave it in default mode (0dB gain).
The front panel – volume control
The aluminium volume knob located near the right edge of Pro iDSD’s front panel is large and very easy to use. Our Pro iCAN uses the very same one and it does the job nicely! Why fix something that’s not broken? The Pro iDSD volume knob can be operated by hand or by a small remote control (included with the product). And lastly, in the bottom right corner of our flagship DAC, you’ll see a small black screen with an infrared receiver. No guessing what that’s for!
As per usual with iFi audio products, the volume control should be around the 12 o'clock position during normal listening levels. In order to have them higher, you can increase the gain via small nearby knob.
Stay tuned, Pro iDSD’s rear is coming up next!
Feb 1, 2018 at 3:18 PM Post #29 of 2,185
Question: for owners of the Pro iCan; is it possible to use the tube mode(s) simultaneously on both the iCan and the iDSD, or it’s not possible or not a good idea? thanks
It is possible and there's no reason why this should be in any way dangerous. It's up to one's subjective ears whether he'd like to have this much valve charm in his setup.
Attention should be paid to gain, though.
Feb 5, 2018 at 8:12 AM Post #30 of 2,185
Crikey this looks exciting and (at least to my eye) beautiful. Even my (very aesthetically driven, especially when it comes to my array of gadgets) wife looked over my shoulder and said "ooh, that's pretty! Erm... what does it do?"
Unfortunately well outside my current price bracket, though would love to have a listen and a play if there is a tour coming up!
