Ross Kyle
the one before the signature modelWhat do you mean OG pro ican?
Oh ok… is it more powerful? Does it work better than the signature with Susvara?the one before the signature model
No, the power specs and functionality are exactly the same between the OG iFi iCan Pro and the Signature version. They made some internal upgrades for the Signature version. In theory, your upgraded version with newer internals should work better with Susvara and other headphones than the OG model.Oh ok… is it more powerful? Does it work better than the signature with Susvara?
If the same wire quality, it's the plug quality.Guys is there any specific reason why I get perfect sound from xlr, but low volume and muddy sound via 4.4mm?
I just bought my unit
4.4 is IEM-match.Same cable (4.4mm) used with an xlr adaptor
Xlr miles metter
Are you sure? So I can’t use it for full sized cans because it lowers the power?4.4 is IEM-match.
Yes, Built-in IEMatch -18dB.Are you sure? So I can’t use it for full sized cans because it lowers the power?
Oh ok I didn’t know!Yes, Built-in IEMatch -18dB.
Oh interesting. I missed the memo on that and it's non adjustable. My full size can only has 4.4 and 6.3 so that's a potential issue.Yes, Built-in IEMatch -18dB.
Depends on how hard they are to drive and how much EQ you use (headroom). With no EQ the HD800s is plenty loud out of the 4.4 around 11 o’clock on the volume dial. And you have the 6.3 if you need more volume.Oh interesting. I missed the memo on that and it's non adjustable. My full size can only has 4.4 and 6.3 so that's a potential issue.
It's a USB 3.0 A to USB 3.0 B cable. A is the flat end, B is the squarish end. 3.0 refers to the speed (and is signified by the blue plastic in the connectors) and for this kind of thing you only need USB 2.0 because there is nowhere near the data transfer rate in doing (say) a backup - not even close.That being said....... Can someone tell me what kind of USB cable this is, so I can buy a longer one on Amazon? Are there "better" ones out there? Can someone give me a link to a good one. Thanks
Check your adapter with a different source?Guys is there any specific reason why I get perfect sound from xlr, but low volume and muddy sound via 4.4mm?
