iFi audio Pro iDSD (Official) - NEW Firmware - MQA and more.
71 72 73 74 75 76 77 78 79 80
82 83 84 85 86 87 88 89 90 91
  1. gordec
    For bridge mode, here is a tutorial how to set it up. https://www.windowscentral.com/how-set-and-manage-network-bridge-connection-windows-10 The last step is important make sure you manual assign the bridged ethernet port with its own IP address.
    Basically, you will connect your laptop to the internet via wifi to your router, you will have connect the Pro iDSD to your laptop via ethernet cable. The bridge mode allows your laptop to serve as a router and share the connection with Pro iDSD.
    This way it's like a direct connection from PC to Pro iDSD. My $10 Ethernet cable sounds better than the $500 Wireworld Platinum Eclipse USB cable.
  2. iFi audio
    You're welcome!
    iFi audio Stay updated on iFi audio at their sponsor page on Head-Fi.
    https://www.facebook.com/iFiAudio/ https://twitter.com/ifiaudio https://www.instagram.com/ifiaudio/ https://ifi-audio.com/ info@ifi-audio.com
  3. gordec
    @iFi audio Can you ask your tech team if the network stuttering with anything 192k or higher is something that's fixable with firmware or it's a hardware issue with memory and buffering that we are going have to live with. Right now I'm downsampling everything to 96k, and I have never experienced a stutter. I personally can't hear the difference between DSD vs 96k downsampled DSD, so it probably won't make real life listening difference, but part of me like to know I'm playing straight up DSD. Thanks.
  4. va1enr0y
    I'm going to be returning mine, frustrating as hell to use as a network streamer for my DSD and MQA files.
  5. gordec
    What are you using for streaming? You need to downsample to 96k.
  6. iFi audio
    We will.
  7. va1enr0y
    JRiver & Audirvana streamed directly to the iDSD via DLNA. I prefer to play my files as they are. For the price that I'm paying, I shouldn't have to compromise by down sampling my files.
  8. gordec
    I can't really think of a reason to talk you out of returning it. The Pro iDSD does sound superb. After I put in the JW Western tubes, the sound became so full bodied with impeccable imaging. It just reinforces the awesome Susvara sound signature. I think you could just rebuy it if they do fix the network buffering issue. I just hope it's a software issue.
  9. iFi audio
    To double-check, this issue is still on with FW 2.01, right?
  10. bluesaint
    Absolutely still happening.
  11. iFi audio
    Alright, we'll check this.
  12. gordec
    Correct
  13. tinnitize
    Ceterum censeo frontis panellum esse modificandum.
    (Cato today)
    Happy Easter!
    Tinnitize
  14. CADEng
    Hi guys,
    this is my first post here
    I am a little bit lost in translation because I have good localy offer to buy iDSD but I have less then 24h to make my decision.
    Don`t have time to read all those posts here and I have few questions.
    I want to use iDSD over ethernet connection to router for TIDAL streaming with MQA and over USB hard disk for the rest. Clean iDSD without PC/Mac etc just Muzo app (or maybe some other app? )
    What can I expect regarding sound quality? Is there some way? Can some summarise me in short Pro&Cons for my wanted solution because I find out here that there is some problems with this approach for listening?
    Thanks!
  15. gordec
    You mean you don't want to use a computer at all? How are you hosting the files? External hd connected to idsd directly or NAS? Muzo is not a great option. If you want Tidal MQA, Audirvana is the only option.
