iFi audio Pro iDSD (Official) - NEW Firmware - MQA and more.
post-14282991
Post #181 of 1,603
bluesaint
Tech shuttle Yay area
@iFi audio I ordered and waiting for mine to come in (this week). Quick question, as I have iCAN Pro as well, Is there a suggested mode to connect the two? ie. If i'm listening on Tube mode on iCan, should i set the iDSD Pro in Tube mode as well? What about gain? Basically trying to understand the balance/synergy when pairing the 2 together.
@iFi audio would you mind responding?
post-14283013
Post #182 of 1,603
hop ham
I got a defective unit, sigh, now I have to wait for dealer to get an answer from iFi on how long it will take to get a replacement. After such a long wait this is a bummer but I understand things like this happen. I'm gonna give this another shot.
Reactions: alphanumerix1
post-14284733
Post #183 of 1,603
MLGrado
Knoxville, Tn
Knoxville, Tn
Age
43
  • filters can be selected for DSD and PCM up to 192KHz
44.1 - 192KHz
  • Additional fixed second order analogue filter @ 80kHz
DSD Filters:
  • Four different filters (selectable) with varying bandwidth
The other resources (website etc.) only list for DSD filter a third order analog 80 khz cutoff with 6 db compensation for DSD level.
No mention of the usual four Burr Brown 8 tap FIR filter choices til I saw it here, so I was confused. So the implementation is like previous iFi products for DSD. Selectable FIR filter, with fixed filter following. (This fixed filter is in place for all formats, PCM included)
My only confusion now is the actual order of the filter (second or third), and how the 6db compensation is applied to DSD only and not the PCM formats?
post-14285297
Post #184 of 1,603
iFi audio
Sponsor: iFi Audio
Website
ifi-audio.com
It's simple. If you use balanced headphone out, then connect both devices via XLRs. If you use i.e. 6.3mm out, then go for RCAs.
We're sorry to hear that. Hopefully it'll work out soon. If not, please do let us know here via PM. Thanks!
iFi audio Stay updated on iFi audio at their sponsor page on Head-Fi.
https://www.facebook.com/iFiAudio/ https://twitter.com/ifiaudio https://www.instagram.com/ifiaudio/ https://ifi-audio.com/ info@ifi-audio.com
post-14287383
Post #185 of 1,603
iFi audio
Sponsor: iFi Audio
Website
ifi-audio.com
The other resources (website etc.) only list for DSD filter a third order analog 80 khz cutoff with 6 db compensation for DSD level. No mention of the usual four Burr Brown 8 tap FIR filter choices til I saw it here, so I was confused.
This is correct. DSD does use a fixed 8-tap analogue FIR filter followed by a passive 3rd order LCR lowpass at 80kHz. The FIR filter was selected for best rejection of ultrasonic noise while allowing full bandwidth.
It is NOT like previous products.
All digital filters are implemented in our new Chrysopeia FPGA based DSP engine, allowing us a wide range of filters IF upsampling (PCM or DSD) is enabled.
It is also possible to completely bypass the Chrysopeia FPGA and to send non-oversampled PCM and DSD directly to the DAC, operating without digital filter for PCM or the aforementioned 8-tap analogue FIR for DSD.
Correct. It is a necessary low-pass to remove ultrasonic noise far beyond the audio range. We use a passive LC (inductor/capacitor) filter that offers its maximum attenuation of ultrasonic noise at around 6MHz and remains effective to beyond 75MHz. In the traditional sense of the word it's not a 'reconstruction filter'.
It is a 3rd order filter (60dB per decade - so 800kHz are attenuated by around 60dB).
As DSD uses a '0dBFS' setting of 50% modulation, DSD is normally 6dB quieter than a PCM version of exactly the same master as for PCM we have a '0dBFS' setting of 100% modulation.
The gain compensation add 6dB extra gain for DSD and thus removes the actual and perceived level differences.
post-14287644
Post #186 of 1,603
MLGrado
Knoxville, Tn
Knoxville, Tn
Age
43
Thank you. That clarifies exactly what I was asking. When I said it was like previous implementations, I was only referring to the general architecture for DSD when using 'Direct' mode. The unaltered bitstream goes to the FIR filter like in previous products for conversion, with a second fixed filter to follow. But if now the FIR filter is set at a fixed setting, then in that sense it is also NOT like previous products.
Sorry for the confusion!
Thanks so much!
post-14288136
Post #188 of 1,603
alphanumerix1
Brisbane, Australia
Brisbane, Australia
very nice indeed.
post-14289539
Post #189 of 1,603
MLGrado
Knoxville, Tn
Knoxville, Tn
Age
43
I just want to leave a short note of thanks for you guys at iFi. I have pestered a few of you for years about this day, and it has arrived, what I consider the ultimate DSD solution currently available on the market. It truly is a 'have it your way' solution.
If you want DSP processed DSD, you get it. If you want untouched pure DSD with the only conversion element being the final analogue filter, you get it. ( well, as pure as DSD gets in all practicality. One could conceivably use a one bit switch, single tap 'bit perfect' filtering, RC filter, etc etc, but my understanding is this would essentially require a perfect switch and a perfect clock and is not practical. Even with a multi-tap FIR filter doing the conversion, it IS the simplest, purest conversion you are ever going to get for DSD.)
And now you can have state of the art DSD upsampling with the best filters available to do so in hardware, so no need for complicated software to do the trick.
Also, unlike some solutions that only have Galvanic isolation on the I2S bus, but do nothing about pure USB power, nor galvanically isolate said power, the iFi is far superior in this regard, and will not benefit much, if at all, from external Galvanic Isolation, although the OCD in me doesn't want ANY dirty USB signals to cross into the DAC, period. Call it peace of mind :)
It almost like iFi took all these other popular and differing solutions to the same 'problem' and said we will one up you and offer them all. User gets to pick what they like best.
WOW. Just WOW.
Well done, and I can't wait to get my hands on one.
post-14289563
Post #190 of 1,603
iFi audio
Sponsor: iFi Audio
Website
ifi-audio.com
Thanks. 'Options' is our middle name.
post-14290446
Post #191 of 1,603
gordec
Any early impressions anyone?
post-14290561
Post #192 of 1,603
bluesaint
Just came tonight!
post-14290563
Post #193 of 1,603
bluesaint
Reactions: superuser1
post-14290564
Post #194 of 1,603
Giraku
NJ, USA
NJ, USA
I got mine about a week ago. I've been overwhelmed by the sheer amount of the options. That's a good thing, but the problem is it will take some serious time to post an impression.
Another problem is that this is so good sounding so that I really enjoy listening through it and forget about critical listening...
post-14290824
Post #195 of 1,603
aterville
Hello,
How do you mange DSD filter I can only access PCMs.
Thanks
Arnaud
