- Mar 20, 2013
Part 6?????
Hi,
Without further ado:
Power supply – With great Power brings great responsibility (part 6/6)
Almost 940uF power supply capacitance directly supports the DAC Chip analogue power supply and a further almost 470uF dedicated to the digital supplies. The digital supplies incorporate three low noise series regulators for the 3.3V supply voltages of different parts of the digital section (including one dedicated for the Audio Clocks only).To maximise dynamic performance, especially with bass, the analogue stage is backed by audio-grade ELNA Silmic Capacitors dedicated only to the analogue stage and additional capacitors giving a total of 1,400uF, while the Headphone Amplifier uses by almost 2,000uF in local power supply capacitance, located within a few mm of the audio circuitry supplied.
All in all, of the iDAC 2 micro printed circuit board, nearly 50% is taken up with power supply circuitry while the rest is used for all other functions. By using such extreme and elaborate power supply circuitry, the iDAC2 micro achieves a new level of dynamic performance in USB powered DACs and a USB powered performance (objective & subjective) that previously required either battery or external mains power.
So while it is good to talk about the digital section and the DAC chip used or not used, we also like to 'go to town' on the analogue and power sections. Hence why we are explaining the work that has gone into the iDAC2. We hope you found these articles interesting as we certainly enjoyed putting them together.
As we always say, the proof is in the pudding.
iFi iDAC 2 Specifications:
Input: USB3.0 (USB2.0 compatible)
Output: SPDIF RCA (only PCM up to 192KHz)
Audio RCA
3.5mm Headphone
Formats: 44.1/48/88.2/96/176.4/192/384KHz PCM up to 32 Bit
2.8/3.1/5.6/6.2/11.2/12.4MHz DSD
353/384KHz DXD
DAC: Bit-Perfect DSD & DXD DAC by Burr Brown (1-DAC; 2-Channel; 4-Signals)
Filters: -PCM: Bit-Perfect/Minimum Phase/Standard, Digital filters selectable
-DSD: Extreme/Extended/Standard, Analogue filters selectable
-DXD: Bit-Perfect Processing, Fixed Analogue filter
Line Section:
Output: 2.1V (+/-0.05V) fixed
Zout: < 39 Ohm
SNR: > 114dB (A) @ 0dBFS
THD+N: < 0.0025% @ 0dBFS (100k Load)
Headphone Section:
Output: > 350mW (2.40V) into 16R (<10% THD+N)
> 34mW (3.20V) into 300R (< 0.1% THD+N)
Zout: < 2 Ohm
THD+N: < 0.0025% (1V into 16 Ohm, 0dBFS)
SNR: > 114dBA (3.2V into 16 Ohm, 0dBFS)
General:
Power consumption: <1.5W
Dimensions: 158(l)x68(w)x28(h)mm
Weight: 265g(0.58 lbs)
Thanks.
Stay updated on iFi audio at their sponsor profile on Head-Fi.
