iFi audio iTraveller - A Multi-Purpose Travel Case Designed For Portable DACs!
Mar 8, 2021 at 6:29 PM Post #16 of 37
Tex Irie
Adventures In The Land Of Music
A place for everything. Keep your audio life organized with iTraveller!
A multi-purpose travel case designed specifically for portable DACs
Goodbye tangles, hello tidy…
The travel companion for audio on the go, designed with plenty of cleverly-divided removable and flexible compartments.
Fits all your audio accessories
Organised and tangle-free
Designed specifically for portable DACs
Opens out flat for easy access
Dual connection ports for simultaneous use of different cables
Outer storage pocket giving you quick and easy access to your playlist
Elastic belts and mesh pockets provide great flexibility when organising your accessories
Soft, padded, removable partitions to protect from scratches
Water-resistant fabric and self healing waterproof zips
Dimensions: 135mm (5.4″) x 190mm (7.5″) x 50mm (2″)
Learn more: https://ifi-audio.com/products/itraveller/
Buy now: https://ifi-audio.com/buy/itraveller/
Well timed!
Mar 8, 2021 at 7:00 PM Post #17 of 37
Sebasistan
Chicago
Does it come with an in-built GPS locator chip, in case it gets swiped? :D
Mar 8, 2021 at 7:40 PM Post #18 of 37
Colorado
Looks interesting. Is it campatible with Micro Black Label?
how do you adjust the volume with the amp inside the case?
It is! It's compatible with our Diablo, Signature, Black Label, and anything smaller length-wise.
Well timed!
We hope so!
That's a great idea, but unfortunately no! We trust you can watch whatever gear you put in there like a hawk.
Mar 10, 2021 at 11:38 AM Post #23 of 37
markel
Dallas, TX
Wow, cared to share some photos with the Hugo inside the case?
Was thinking about getting a case for mine and wonder how this would work...
I'll post some photos tonight. Hugo 2 fits nicely and there is plenty of room inside and outside for a phone to connect to it or you could connect a DAP. I have a giant 1/4" connector stuck in the headphone jack on the H2 and it still has room. If you are using IEM's, then there should be room to put your IEM's above the H2 when you aren't using them. The H2 takes up about 95% of the space in width, but only about two-thirds of the length, and there is plenty of depth. I'll put some IEM's in the case and show how it looks. When I got it, it was full of all the Diablo accessories and I didn't even think of using it as a travel case, but when you empty it out, it is a pretty flexible pack, even to use moving things around at home. It is also high quality material.
Mar 10, 2021 at 11:58 AM Post #24 of 37
Colorado
@Sebastien Chiu Does it fit the newly announced Cayin C9?
I couldn't find the dimension to that anywhere.
I'll take a look at the dimensions and get back to you on this! If it's a standard-sized DAP and not abnormal anywhere it should!
Mar 10, 2021 at 9:38 PM Post #25 of 37
markel
Dallas, TX
Here are some photos with the Hugo inside the case.
Mar 11, 2021 at 11:27 AM Post #28 of 37
Colorado
