iFi audio iDSD Diablo - A portable reference done our way!
Apr 20, 2021 at 5:23 PM Post #1,276 of 2,429
Convolver
New Mexico
My Diablo works fine on a stock 7.0 firmware. All led colors are correct: mqa - green, mqa studio - blue. Running it out of ROCK on NUC (Roon Linux based OS).
My early serial numbered unit came back from service today after they "flashed the PCB" to fix the LED color issue. The good news is that now MQA always shows magenta, where before it seemed to be randomly yellow or whatever.
I tested Diablo using PCM only (no DSD) to discover that indicator colors have changed, but are still not correct:
44kHz and 48kHz files result in a yellow LED, not green as described in the literature.
Other sampling rates produce white, not green (88,96), and not yellow (176, 192, 352) as described.
I did not try 384kHz (supposed to be yellow) or 768kHz (supposed to be white).
All could be forgiven if the promised MQA decoding through SPDIF input had been enabled, but that didn't happen, either. Oh well.
EDIT: I do get green with basic MQA and blue with MQA Studio at any sampling rate (as qsk78 says above) when not using DSP after Roon does the first unfold.
Apr 20, 2021 at 5:31 PM Post #1,277 of 2,429
Dgowland
Washington
Any news regarding incorrect mqa led behaviour? My unit shows yellow led when playing "second level" mqa (green dot). MQA Studio (blue dot) led status is shown correctly - Magenta. Changing dac setting from decoder to renderer when playing "green dot" mqa corrects led to magenta but also alters the sound slightly when used with ASIO driver. My question is if this is only issue of correct led status, or is it a firmware issue and "green dot" mqa's are not decoded at all - therefore no magenta...
Another point of interest, when playing mqa 24/192 audirvana shows 32/48 at the dac's end with asio driver.
I had this issue for a couple of days. After some tinkering with settings and downloading USB Audio Player with the MQA add-on it was fixed straight away.
Apr 20, 2021 at 7:19 PM Post #1,278 of 2,429
Convolver
New Mexico
QUESTION: When firmware with the GTO filter is used, do we still enjoy the same MQA benefits plus whatever GTO brings to the table for non-MQA material? Or does that firmware produce a different sound from MQA files as well?
I am running version 7.0 and would rather not change it unless others are reporting significant improvements across the board.
Apr 20, 2021 at 10:23 PM Post #1,279 of 2,429
justanut
Singapore
Difficult to say which sounds better unless someone rocks 2 Diablos with different firmwares. I’ve tried flashing to n fro. But auditory memory is fleeting.
Apr 21, 2021 at 12:57 AM Post #1,280 of 2,429
qsk78
Russia
Mine is a Decoder and Renderer in settings, so no Roon involvement into unfolding process
Apr 21, 2021 at 5:10 AM Post #1,281 of 2,429
Bob Parish
Brasil
7.0 sounds way better than GTO 7.0c. Period!
I compared both firmwares sound a few posts above...
Apr 21, 2021 at 7:20 AM Post #1,282 of 2,429
MQA can't be processed in any way to remain MQA, which is why our GTO filter doesn't affect it.
https://www.facebook.com/iFiAudio/ https://twitter.com/ifiaudio https://www.instagram.com/ifiaudio/ https://ifi-audio.com/ info@ifi-audio.com
Apr 21, 2021 at 10:12 AM Post #1,285 of 2,429
qsk78
Russia
You must also have “Enable MQA core decoder” turned off in Roon audio settings. Otherwise, Diablo will act as a renderer.
Ok. Got it. Now it is fully on Diablo side)
Apr 21, 2021 at 1:12 PM Post #1,286 of 2,429
Southern California
