iFi audio iDSD Diablo - A portable reference done our way!
Jun 16, 2021 at 6:51 PM Post #1,501 of 1,613
utdeep
Also, the HiRes sticker makes the bass deeper, the mids recessed, and increases my desire to buy expensive cables
Jun 16, 2021 at 6:52 PM Post #1,502 of 1,613
utdeep
Did I mention that I think the sticker makes more of a difference in my setup than the iPurifier?
Jun 16, 2021 at 9:31 PM Post #1,503 of 1,613
Bob Parish
Brasil
LOL..., I was asking if there was an update from the first to the second batch that changed the already good sound!
BTW, if you change the place of the HiRes sticker, you can get a more forward midrange and better dynamics!
Adjusting the HiRes sticker place changes the sound character... :sweat_smile::sweat_smile::sweat_smile::sweat_smile::sweat_smile::sweat_smile::sweat_smile:
Jun 16, 2021 at 9:54 PM Post #1,504 of 1,613
utdeep
I’m about to start a business making hires stickers with mystical properties. I pity the iFi Diablo customers who got version 1 without the sticker….
Jun 17, 2021 at 1:01 AM Post #1,505 of 1,613
qsk78
Russia
  • The iTraveller is perfect for the Diablo and any high-end DAP
Interesting. I still have a lot of questions to the iTraveller. Yes, it is nice to have it in the package but practically I don't find it very useful.
Did you try to adjust volume on the go in the iTraveller?
I use the Pelican case 1060 for transportation only (to put it in your backpack if needed). It definitely protects.
And I do use Vannuys VC911 if I want to listen to on the go, with open ends from both sides which I find more convenient.
Jun 17, 2021 at 1:38 AM Post #1,506 of 1,613
Terr0rSandmann
Germany
Diablo, Valkurie, Qudelix 5K and a lot of cables and adapters. Unfortunately my AirPods Pro will not fit as well 😅
Jun 17, 2021 at 1:41 AM Post #1,507 of 1,613
qsk78
Russia
This is clear that you can put many things inside. Did you try to use in on the go?
Jun 17, 2021 at 1:49 AM Post #1,508 of 1,613
Terr0rSandmann
Germany
No. My on the go setup is Valkurie + Qudelix 5K. Much more comfortable with such a small device and Bluetooth. I use the iTraveller more as a audio bag / transport case.
Jun 17, 2021 at 4:05 AM Post #1,509 of 1,613
CH23
You wouldn't be the first one, but I hope yours won't cost €6.50 per sticker :p
Jun 17, 2021 at 9:21 AM Post #1,510 of 1,613
utdeep
I've used my entire setup in the iTraveller and was able to control volume and song.
I"d charge at least $300 for the sticker. If it's not expensive, how would anyone know it works??
iFi products should be 10 times more expensive.
Jun 17, 2021 at 3:32 PM Post #1,511 of 1,613
utdeep
Look at this! I found a think leather Miter case to protect my new Diablo and the HiRes Sticker! Required for anyone with version 2 of the Diablo.
Pretty nice. Unsure if this affects any heat dispersion.
Jun 17, 2021 at 4:07 PM Post #1,512 of 1,613
Terr0rSandmann
Germany
Do you think that this is a good idea? Because the Diablo is getting a bot warmer in turbo mode and it will not be able to breath with a full lether case.
Jun 17, 2021 at 5:01 PM Post #1,514 of 1,613
utdeep
it’ll be fine. I put a hires sticker on it to keep it cool.
Jun 17, 2021 at 6:57 PM Post #1,515 of 1,613
CrocodileDundee
Australia/Brazil
