IEM Ear-tip help/recommendation
Sep 21, 2016 at 4:12 AM Thread Starter Post #1 of 1
CVRLO
Hi everyone! I posted this a few days ago in an IEM thread, but no one responded to it. I probably should've done it here first when I signed up for Head-Fi. Sorry.
I recently purchased the beyerdynamic BTA and I like it a lot.
I need to buy SMALL replacement ear-tips since those are what fit me best. I accidentally ripped the SMALL ear-tip that came with the device.
I used the Comply fit chart, and since the BTA's are new, they weren't on the list. I based it off the previous beyerdynamic IEM's, instead of measuring the actual nozzle. I ended up getting Comply T400 and some random SMALL silicone ear tips. They were too big and I returned them.
I included some photos below and a rough measurement (I should've done this in the first place).
My questions are:
1. If I bought SMALL SpinFits, would these be CP100 (larger size) or CP800 (smaller size for IEM's like Shure).
2. Do you think JVC SpiralDots would fit these headphones?
If you have any other recommendations please let me know. I prefer the silicone ear-tips to the foam.
THANK YOU!
In the photo below, the ear tip is inverted so the core is sticking straight up. The diameter of the inside hole is around 2mm.
ROUGH sketch and the measurement might be 1mm off.
