I recently got a some brand new TRN V90 IEMs and since they didn't cost me anything I thought I would upgrade them with a new cable and some other stuff. This is were I've run into a bit of a headache on the box it says that the connector type is 2-pin 0.75mm. When searching for cables that fit the options seem rather limited compared to the rather more common 2-pin 0.78mm connector cables.
Now to the question at hand can you insert a 2-pin 0.78mm connector into a 0.75mm port or is that a no go? Does anyone have experience with this situation?
