Dobrescu George
Reviewer: AudiophileHeaven
As many of you know, there is this mod of adding duct tape over ie8 for reducing veil, but it takes away soundstage, and everything, but takes away veil, and makes everything clearer.
after making some tries, with many different materials, with a few equations of including a de-pressurizing and over-pressure of dynamic driver, i had found the perfect mod
The one that was the final best resoult is the one on the bottom. you should try to accomplish that one. use black electrical isolation duct tape that is not too thick, this has prooved the best resoluts sonically.
the ideea is to make it from two parts and let a little free part, exactly where the volue parts are. you should immediatly hear sonic bliss.
This is just a personal discovery, feel free to use it, and give back impressions.
EDIT::: after some more usage, i found that this only works well with double flange tips. any other tips will give back veiled or not enough bass sound. this mod creates much more details in bass region, but modifies how bass is distributed, there is less veil, more sub bass and the mid bass hump now sounds musical and organic instead of veiled and too thick. it still is a little thick, if you ask me.
