late to the party, but the party is still going on...
https://www.head-fi.org/showcase/ibasso-sr1.23596/reviews
Can you try swapping to CB12s cable? I find them quite an upgrade to SR1
I have that cable here and will give a try then. Thanks.Can you try swapping to CB12s cable? I find them quite an upgrade to SR1
I was kidding with you about the 1 star. I figured something went wrong, since your review was positive.I have that cable here and will give a try then. Thanks.
I used to try most cables i have for head/earphone reviews, lots of tip rolling for earphones and also cable changes, test with several daps etc etc...
-and try to answer every possible query in a review.
Ended up ‘too long didn't read’ for most people, the other side now is ‘too short!’
LOL
But any tweak that might give improvements i am down to try.
It will probably set me on a course to cable roll a few other MMCX cables i have lying around...
Thanks for sharing those photos. They are very helpful. Can you describe how the sound changes compared to the original pads? Thanks again.They fit, bit small but fit.
You're exactly like me. When I bought the TH900 used, the pads were no where near the condition it was described to me. So I never got to know the stock pads sound signature. . So I ordered the HE6 stock pads and have them on my TH900 now and they for perfectly. And I don't have time now to test them. That's why I thought I could also try these PT1 on my HE6.Good thing you bought just one Set @Rayzilla I'm not sure but I'd guess those pads are too small for he-6.
Unfortunately I can't comment on the soundquality. I'm not familiar enough with stock th900 and I don't have time to compare more right now.
How do these hold up against the audeze lcd2c or sine (dx)?
Been lookin for the pt01 pads but looks like they sold out everywhere. Any other good pads that'll be a good fit?
