Lohb
Looking good Mike regarding the OPAMP technical stuff....
I just picked up a better quality than generic printer cable, and after half-an-hour, worked the 4th pin completely out with a razor and tweezers as per your data-only USB plug method for split USB cables.I used tape for the 4th pin on another previous cable, but it never lasts when you remove the USB cable from the port daily.
http://www.head-fi.org/t/647693/sonic-satori-hrt-levels-the-field-with-the-microstreamer/1155#post_12640560
Will have my Hirose male plug fitted on an 8-line Sterling Silver IEM cable by tomorrow locally....
But I know I cannot AB exactly, even taking account for volume. I find the middle/high gain adds more bite/attack/dynamics to the presentation for some reason, and I think it is not purely volume but the impedance or something is working with the end IEM/headphones to present it slightly differently....I think that came up in the H10 thread as well.
Have yet to see if the base of the case can screw off, if yes, may anodize it or power-coat upper and lower case and leave the rear and front as it is.
Just pulled the AD797...found them too dry in the mids/treble...now using OPA604 + dummy buffers which has a richer tone and fuller sound than AD797... until I can get my hands on DIP8 units to raise 2 of the Bursons up and keep 2 low.
