Dobrescu George
Reviewer: AudiophileHeaven
George! As always great review man!! An excellent read!
I wish I could write as well as you do. lol
Thank you!
Been enjoying mine for the past couple weeks. Definitely breathes new life into my music.
Although one issue I've encountered with mine is I was not able to get any sound out of the right side unless I spun the cable near the connecter a certain way. Then over the weekend I tried disconnecting the earpiece from the cable and reconnecting it, but I seem to have lost all sound from this side. I'm not sure if it's me, the cable, or the iems. Any help/advice would be greatly appreciated as I'd love to get back to enjoying the IT01's!
Will do, thanks!Try to contact iBasso, I think they will help you solve your little issue
Actually just bought a iFI iEMatch to deal with background noise, my X7 has 2,2 Ohm.
I bought it when I had 712 pro and other full sized headphones, before realising a decent iem was everything I needed.
Shanling M3s. There is a used one on the sales forum for $230ish. with case. Solid deal. Great sounding player. The M3s has dual everything on the hardware side and it clearly shows in the balanced. Single end is no joke either.
3.5.Is the 3.5mm or 2.5mm iematch? I was thinking the 2.5 version might be worth trying with the M3s balanced output.
3.5.
I'm surprised a 2.5 version even exist: aren't 2.5 balanced amp designed for iems in the first place?
