Ivan TT
I actually agree and retract my earlier comment, IT01 has quite deep sub-bass, especially after I found right fit, tips and put some foam inside of the tips, DIY hybrids Obviously I cannot compare it to CH9T until my replacement unit arrives, but form the memory CH9T bass and sub-bass are a bit more precise, while IT01 is a bit warmer.I'm not really surprised, my earlier thoughts are still the same. The IT01 still goes deeper and has more quantity than the CH9T
In other words and speaking technically (yet subjectively, of course), CH9T seems to react very quickly to transients, not changing ADSR (aka envelope) of LF sounds, so they hit a bit harder yet do not "reverberate", while IT01 seems not too have as fast transient response, this may and most likely will change with burn-in as many posters mentioned tidying up of bass over time. Also, IT01 seem to add harmonics to LF sounds (hence "warmer" bass and quantity), while CH9T just gives you pure fundamental, sounding somewhat colder, although this may be due to CH9T's scooped out mid-bass...
Anyway, to not to confuse things further my conclusion is: IT01 is DEFINITELY a keeper!
