Klonatans
- May 30, 2014
I have tried it, to skip and it works but maybe I don't understand what you are doing?
Probably yours doesn't have this issue.
Hmmmm, is the pop sound issue while skipping track not solved? Is frustrating to hear the pop sound every time the track changed.
It's unfortunately hardware-related and caused by the used DAC chip when the bitrete changes.
Do you know if other daps using same dac suffer of this same problem?
Hi guys, i just got my ibasso dx80, i have firmware 1.5.8 installed on it, im using always equalizer on other devices so i wanted use eq on ibasso also... im having problem with 16k band, i push it to the 12db up, but after next song the 16k band goes back to 0db, it still showing 12 db but sound is on 0db, i must take the band a little down and than back to 12db so i can hear the difference... sorry for my bad english...
