iBasso DX50 MODS
post-11634347
Post #196 of 374
Reima
   Just never liked that they do not give a s really secure enough grip on the HP jack. Ibasso have upgraded the sockets on the most recent batches. (it is the new Ibasso sockets I will be using)
Where did you get them?
post-11635825
Post #197 of 374
polyrhythm
Odered direct from Ibasso. I doubt they would want to get into the habit of supplying these though as they would understandibly want to handle 'repairs' etc themselves?
post-11636882
Post #198 of 374
H20Fidelity
Sounds like DX90 sockets which are much better than the older DX50 units. Definitely better grip/hold/secure. One of my DX50 headphone out is becoming quite lazy. Will need replacing pretty soon I imagine.
post-11640514
Post #199 of 374
Mayth
France
France
Hey guys,
Been tweaking my DX50 with many many firmwares as I received my new Momentum 2.0. After 1 week, I found that SU 1.4 is the one I prefer.
I'm highly interested in upgrading capacitors tho seeing everyone seems to notice an improvement.
So let me recap, I should buy 6 Panasonic FC 220uF 10V and replace the LO/HO capacitors shown in the first post ?
post-11641135
Post #200 of 374
CoiL
Member of the Trade: Wood Audio Accessories & Modifications
Estonia
Estonia
4x 220uF 10V (HO) + 2x 100uF 10V (LO) are correct values. I have no idea where did You read "6x 220uF 25V".
post-11641710
Post #201 of 374
Mayth
France
France
Oh, Okay I thought they were all the same. I'm going to order these then.
Anything I should know before doing it ?
post-11641718
Post #202 of 374
CoiL
Estonia
Estonia
Just make sure You know into what You are getting to (how to fully open DX50 and how to (de)solder).
post-11641726
Post #203 of 374
Mayth
France
France
I already had to open it and desolder the Phone out that was moving, my dad did it perfectly.
post-11641744
Post #204 of 374
CoiL
Estonia
Estonia
So, if You have the parts, then there shouldn`t be problems.
post-11642321
Post #205 of 374
Mayth
France
France
Oh crap,
I just realized the one I was about to order are 25V  : http://www.audiophonics.fr/fr/condensateurs-chimiques-panasonic/panasonic-condensateur-low-esr-220uf-25v-105deg-p-5684.html .
The will not work properly, I need 10V caps, right ?
post-11642404
Post #206 of 374
cholero
They work but probably dont fit inside the player. The space is very limited.
They are 8mm diameter, and should be 6.3. Sounds like litte but they wont fit I think.
get exactly the EEUFC1A221S
even the EEUFC1A221 don't fit well because the're longer
post-11642450
Post #207 of 374
Mayth
France
France
Alright, thanks for the fast answer cholero.
Which makes : 4x 220uF 10V (HO) : EEUFC1A221S
                      2x 100uF 10V (LO) :  EEUFC1A101S
Right ?
post-11644600
Post #208 of 374
cholero
For Lineout I dont know
At maximum it is possible to take 2 -S and 2 non-S of the Panasonic FC for headphone out. I've just changed them now :)
post-11644626
Post #209 of 374
CoiL
Estonia
Estonia
I`m not sure if those larger ones are same sounding but since You run them parallel with shorter ones, shouldn`t affect sound much even if they are littlebit different.
Don`t forget to share Your impressions! :wink:
post-11644643
Post #210 of 374
cholero
Sorry I'm not one of those who are able describe sound differences or maybe even hear them. That is why I'm very thankful for all the cap tests you've done. Now I just had to pick the best sonding one and I'm happy. The larger ones I've ordered wrong first but since they have slightly better specs I decided to take them.
