Speculating about some unfinished product?
Apologies for the previous speculations. Those were my assumptions on what little information we haves so far.
We trying to determine things based on what we can find, without actually having the units in question.
So the issue should be to have the information in order for everyone to make their own decisions.
Here is more information more exact determinations.
Manufacturer data Of THX chip (to be used by fiio) from the THX website:
So those are the thx chipset specs.
Fiio said they are trying to maximize the output, as stated before.
So Fiio may be working on the heat dissipation, or may even have some discreet circuit tricks up their sleeve.
So we can
assume that thier chips will be set at or near maximum output, which is stated at 1.850watts(@32ohm)...
It doesn't say either rms or max output, but the clue that there is 15v rails, so I would determine that it is rms.
That is a huge impressive figure.
In comparison, we have the iBasso 220Max output said to be at 1.758w (@32ohm rms)
So, it can be determined that the 220Max is expected to be 100mw just below the theoretical limits of the THX chip, (not the actual fiio unit). This is also an impressive figure.
Next, The Calculated output of the 300max (stated in pic 6.5v@32ohm) seems to be 400mw
lower, 1.32watt rms(!)
So we have a discrepancy of having
less power output in the 300Max.
It does not compute...
If the batteries are larger, why wouldn't the output be greater?
Maybe more stable?
Maybe testing variables?
In time we will find out once they are compared more.
So far comments have stated more sound aspects in the 300max. It was mentioned to have more weight in the bass, which I would figure as a component of more current or signature sound.
We need to know the spec in Amperes to determine its performance for demanding headphones.
Dx220max was 2A. Which was pretty good.
Dx300 with amp11mki was 2.7A.
Sounds like good idea to look at battery amperes. The trend seems to be to have greater amperage.
So let's look at the batteries.
220Max:
4400mAh 3.8V for digital
4 x 900mAh (3600mAh) 8.4V for the Analog.
300Max:
the digital battery has been increased by 1/3...
???? differences???
What matter will be total voltage swings in the end. The true differences between portable vs desktop
It would be interesting to know if there is also a difference here, as the battery voltage is supposed to be the same.
