iBasso DX220Max ****************** New FW! 1.01 for download! 1st Page.
Sep 22, 2020 at 2:00 AM Post #2,701 of 3,626
Here is another solution. This is how to add DAC volume control button on navigation bar.
1. Pull down quick settings panel and press gear icon for about 3 sec then release it.
2. "System UI Tuner" is added on the bottom of Settings>System. Tap "System UI Tuner."
3. Tap "Navigation bar."
4. Set each value as below, then close settings and you will see DAC volume control button on navigation bar.
(You can set "Layout" value as you like.)
*You can see a full list of keycodes (assignable key events) here. Each keycode is listed as "Constant Value" on the linked page.
Well done! Well found!
Sep 22, 2020 at 9:31 AM Post #2,702 of 3,626
It happened that I barely leave home from the second half of March. Working remotely, shopping online... At the end of July I've received my DX220Max. Max+SR1 was* my music source for past two months. Quite a different experience compared to a pocket DAP with IEMs: more comfortable and more enjoyable!
Am I the only who wonders how iBasso managed to release the DAP made just for this situation? Just in time :) It's a pity it is LE!
* "Was", because SR2 just have passed initial burning in, but it's another story...
Sep 23, 2020 at 7:57 AM Post #2,704 of 3,626
Sep 23, 2020 at 12:02 PM Post #2,705 of 3,626
I don't see how DX300 will beat MAX in sound quality. MAX and Sultan combo makes my TC sound less powerful through WA5, makes me want to get more powerful amp to drive the TC.
Sep 23, 2020 at 12:52 PM Post #2,707 of 3,626
Max has unfair advantage over regular DAPs but at the cost of form factor, a more pocketable DAP might be a good complement... especially when you listen on the move conditions are less ideal so difference in SQ are less emphasized.
Sep 23, 2020 at 1:13 PM Post #2,709 of 3,626
But the Max is still fit into my short pocket.
Treat it as any DAP.
Sep 23, 2020 at 1:41 PM Post #2,711 of 3,626
But the Max is still fit into my short pocket. Treat it as any DAP.
Better have a strong belt then :p
And not fear for the pants / shorts pocket to get bigger lol
Sep 23, 2020 at 4:13 PM Post #2,713 of 3,626
I always put my Max in the side pocket of my backpack.
Sep 23, 2020 at 4:31 PM Post #2,714 of 3,626
Is this good Wifi speed ?
Not bad, nothing to rave about either :p
Let's play this game :
It had been a long time since I have run this... I see my provider has dropped performances should be getting much higher down/up speed (like 200/20)... didn't notice lol
Sep 23, 2020 at 4:45 PM Post #2,715 of 3,626
For a DAP, it is overwhelming!
The whole August I was in a place with 6Mbps/0.6Mbps speed (4G), and it was enough for 3 users, including audio streaming, Youtube, and I've managed to make and publish DX160 add-on update :D
