WindowsX
Member of the Trade: Fidelizer Audio
- Apr 27, 2007
Glad to hear that.
Regards,
Keetakawee
Regards,
Keetakawee
Here's proper 2.0.78 Purist ROM. Fixed missing symlink files and tested bluetooth function. You don't have to flash official OTA before now too.
http://www.mediafire.com/file/y8h3mgmjh0r9onm/DX200-2.0.78-WindowsX-Purist.zip
Regards,
Keetakawee
Installed and did factory reset. Physical buttons swapped on stock and Tidal/Spotify.
Proper ROM should have buttons working correctly with stock Tidal/Spotify/JOOX removed. Please flash with restore option to wipe everything and try again.
Regards,
Keetakawee
There's 'Upgrade' and 'Restore' option in FactoryTool. I hope you can see it by now.
Top button is previous
Middle button is play
Bottom button is next
Is that correct?
Is that correct?
I repacked the same files from OTA with boot information and kernel applied. I see. I'll see what I can do about it. Hope this isn't serious issue for now.
Regards,
Keetakawee
Are You going to fix buttons swap?
