yannis
@javre76 Why did you wait so long?
I like iBasso because I can easily change firmware to whatever version I want
Everything is possiblewhen we can have a new mango player on a mango os for dx150? is that even possible?
My latest FW was 1.04, I had everything organized the way I wanted and my OCD was preventing me to wipe it out and update.@javre76 Why did you wait so long?
Where can i find the Mango OS? I thought, my dx 150 runs with android 8.1. I didn't find an answer, what Mango OS in fact should be. Or is the modfied Android 8.1 for dx 150 the mango OS?Anyone facing battery issue on newest firmware? My dx150 battery performance had reduced from 8 hrs to 6 hrs after upgrading. I always use mango OS.
Thank you yannisMangoOS is separate linux based operating system.
Its "Pure Music" mode. Cleaner sound, extended battery life...
You need to install latest official firmware - http://ibasso.com/uploadfiles/download/DX150FW-ota-1.06.zip
And then iBasso DX150 firmware add-on by Lurker - https://github.com/Lurker00/DX150-Firmware-Add-on
Enjoy!
Thanks again for your help. I had to try multiple times to get the Android Tool to work, but I did eventually get the latest firmware installed and my AMP9 works now.
Thx I'll look into thatNot mac user here but heard of Parallels Desktop.
Did you try it?
There is a guide how to flash full firmware image using bootable SD-card. Works for any Android version.I'm pretty good with android, but don't have a windows computer that I can install the 'android tool'. I only have a mac, so I'm not sure if there is a guide on how to wipe and flash the beta image using the
This comment is not ill intended. Is this worth it? Is it stable enough? Last time I tried it was a little bit messy to install and the results were very unstable. I am currently running OFW with Lurker’s add-on with great all around stability and functionality. Comments will be appreciated.iBasso DX150 Oreo 8.1 Purist ROM version V1.06.085 released
https://www.fidelizer-audio.com/ibasso-dx150-oreo-8-1-purist-rom-version-v1-06-085-released/
-Based on firmware version Oreo 8.1 V1.06.085
-Added MangoPlayer from iBasso DX220 1.13.233 ROM
