Zeo-Gold92
is there a way to remove the lurker addon without a full reset?
I cant find where to restore to factory.
Apply the latest official OTA update, and it should remove the add-on from the device.is there a way to remove the lurker addon without a full reset?
so apply 8.1?Apply the latest official OTA update, and it should remove the add-on from the device.
Apply the OTA: http://ibasso.com/uploadfiles/download/DX150FW-OTA-v1.03.036.zipso apply 8.1?
Very true but I would like to know if I have it on low gain, would it limit the max power output as compared to high gain? As with home theater amps I always perfer to set them lower on gain as they do not limit power output and at the same time benefit from lower noise. Wondering if it works the same in amp 8.i would say listen and decide
Is it worth installing Lurker's firmware? Is it a lot better than stock? How stable are his firmware compared to stock?
how much longer is the battery live with the lurkers. approximately.You can switch to Mango player [only] (without the android stuff)
You should also get more battery life using Lurkers O/S
Does Mango player only mode improve sq at all?You can switch to Mango player [only] (without the android stuff)
Im not particularly impressed with the player over all - for £500 there should be no stuttering / long pauses etc
beyond that the sound is great, although again 1x card slot is a bit of a piss take for that kind of money :/
End fo the day though I certainly dont regret the upgrade from the DX80
