Had the same, a new TIDAL update seemed to fix it (no issues so far...)Hi @Paul - iBasso
I've got (not only me) problem with Tidal Master - sound is "choking". WiFi is ok, and Tidal soft without Master option is working perfect.
Are you guys working on new soft update for DX150?
iBasso DX150. Dual dacs and interchangeable AMPs. **NEW Firmware that supports AMP9! ** New FIRMWARE 1.05 Dec 30.
- Thread starter Paul - iBasso
javre76
- Mar 15, 2016
FIIO worries more on creating new products instead of continue supporting the ones that they have... I guess is their business model, but the customers are the ones that suffer (a lot) afterwards. I have not experienced that with iBasso yet.How were you burned by the X5iii. I am going to try the M11 along side the DX150.
Are you talking about Tidal 2.11.8 april 2nd?
I'm on 2.11.8.899.1. No idea if it was released on the 2nd of April. As I said, I had the same issue with Master files, before I updated to this version / didn't encouter it with this version yet.
Thank you. Now... it's working.
borjok536
- Aug 29, 2009
I need your advice please.. Im on android 6. do i need to update it to android 8? is yhere a significant performance upgrade?
oreo is faster. do it.
pcyco
- Apr 18, 2013
good morninng!
is there a way to "deactivate" the side slider in the mango-player. its impossible for me to reach the checkboxes for albums etc. without scrolling.
to add songs to a playlist with the + and selecting a playlist does nort work ???
regards thomas
regards thomas
Arghavan
- May 16, 2017
I don't think there is. You can use other music apps though. I believe UAPP has direct access to the DAC.good morninng!
regards thomas
Hi guys, can someone post a link to Lurkers firmware for the DX150 please?
jon parker
https://github.com/Lurker00/DX150-firmware/releasesHi guys, can someone post a link to Lurkers firmware for the DX150 please?
mBcHc
- Feb 4, 2013
Just Onboard with the dx150 hype train , from x7i.
One quick question about the volume scroll wheel, how can I lock it when the screen is off? It gets a little irritating for me to always accidentally increase or decrease the volume when my dx150 is in my pocket. Thanks a lot!
borjok536
- Aug 29, 2009
install a volume locker sir
buonassi
I just bought a second hand dx150 so I'm looking forward to joining the ranks!
Tried searching this thread to no avail. Please know that I did that first, before asking the community to hold my hand on this. My question is about SRC:
Ibasso makes mention of bypassing Android sample rate limitation (avoids src). I have to assume this only applies to the stock player and not to a sideloaded tidal apk. Can anyone confirm?
For the record, my SR15 does indeed play native sample rates with tidal apk offline as does hiby r6 (obviously) which I just sold.
Thanks in advance for your guys' knowledge on this.
-Vince B
-Vince B
Arghavan
- May 16, 2017
Yes, in the default firmware it only applies to Mango (stock) player. however If you flash @Lurker0 addon there is an app called USB Audio that enables other apps to have direct access. I could be wrong though, Luker himself can elaborate more on this.I just bought a second hand dx150 so I'm looking forward to joining the ranks!
-Vince B
