iBasso DX150. Dual dacs and interchangeable AMPs. **NEW Firmware that supports AMP9! ** New FIRMWARE 1.05 Dec 30.
Discussion in 'Portable Source Gear' started by Paul - iBasso, Mar 9, 2018.
150 151 152 153 154 155 156 157 158 159
161 162 163 164 165 166 167 168 169 170
  1. jon parker
    Hi Thomas
    I had this exact same issue - I went back and downloaded and installed the original android O/S and THEN upgraded to the latest
    This then worked for me
    Hope that helps
    1, this one: DX150android O, Beta, Dec 14th, 2018 File size: 1KB2018-12-15
    and then
    2, this one: DX150android O, V1.0, Dec 26th, 2018 File size: 756.36MB2018-12-27
    I then went to the latest and updated from that
    pcyco likes this.
  2. pcyco
    @jon parker thanks a lot. i´ll give it a try.
    i will tell :)
    regards thomas
  3. pcyco
    @jon parker did you update the last one from the sd-card??
  4. jon parker
    It didnt work for me to try to update the latest firmware from the SD card
    I had to download the tools > install the early O/S > then update [using the tools] to the latest
    pcyco likes this.
  5. pcyco
    ok i have seen it is updated to build 1,03,036 Androidversion 8.1.0 . anything else todo ? i think this is now the latest version.
    oh man i can buld houses but run a androidsystem is not my world :wink:
    thomas
  6. jon parker
    pcyco likes this.
  7. javre76
    Now that the hype of 8.1 has somehow dissipated... what are the real benefits of updating from 6.01? I enjoy pure Mango a lot and I am still in Lurker’s previous version.
    pcyco likes this.
  8. Zeo-Gold92
    What is the best size to have as the cover arts for this?
  9. jon parker
    Not sure about the size although 1200x1200 or 1600x1600 we use at work
    I would say it is more important to keep the file size below 500kb - If above 1MB sometimes this can cause a delay when moving from one song to another
    Arghavan likes this.
  10. Bookbear
    I find a cover art size of between 400 x 400 and 500 x 500 works well.
  11. Zeo-Gold92
    So I havent actually had a proper chance to try this with an SD card but I just tried using my SDXC . it clicks as if its going in but then it doesnt. Is the card not the right size?
  12. jon parker
    Same for me - the fit is little tricky. With mine I have to push it down further than normal - you need to gently but keep pushing it in. Sometimes it feels like it kind of has to click in and then drop into its place
    So click - then down a tad
    Hope that helps!
  13. Zeo-Gold92
    Oh dear, really? That sucks, mine keeps feeling loose and that little hook on the card keeps snagging
    im worried about damaging both ;_;
    is it tough to get back out?
  14. Zeo-Gold92
    EDIT: I'm an idiot, was putting it in the wrong way...
    it doesnt go in upside down does it ? o.O
  15. jon parker
    If you are looking down at the screen the copper contacts on that back of the card should be facing upwards and enter the slot first - so it looks like its going in upside down
    perhaps you are trying to put in it the wrong way up...because you are from Australia ?? :D
    skingg likes this.
