iBasso DX150. Dual dacs and interchangeable AMPs. **NEW Firmware that supports AMP9! ** New FIRMWARE 1.05 Dec 30.
Discussion in 'Portable Source Gear' started by Paul - iBasso, Mar 9, 2018.
145 146 147 148 149 150 151 152 153 154
156 157 158 159 160 161 162 163 164 165
  1. XP_98
    Hello
    I have just successfully installed the Lurker ROM on my new DX150, I already see the increase in reactivity :)
    As I plan to use only Neutron ( and/or UAPP), is there a way to uninstall Mango player, or at least to remove it from the two main screens ?
  2. crazyeyes
    If you open up the USB Audio app and click on the 3 dots in the upper right and go to system settings there is a toggle to hide mango player.
    That will hide the app if it doesn't remove the widget from the far left screen that, you can tap and hold and drag to the top of the screen to the remove icon just like any other widget.
  3. XP_98
    Fine, I'll try this !
    Thank you
    Edit : it worked :)
  4. crazyeyes
    You're welcome. Glad it worked.
  5. borjok536
    What are the advantages of updating to oreo rom? Im still on android 6 i can tolerate the lag but if upgrading to oreo will improve battery life a bit taht will be a worthy upgrade.. anyone?
  6. leo5111
    im getting mine today should i install lurkers rom? anyone install power amp on this?
  7. DynnoG
    Yes, I definitely recommend getting Lurker's rom. It is worth it just for the performance increase alone and you also get thr Google Play Store, which is not included in the original firmware.
  8. leo5111
    easy to install?
  9. DynnoG
    Yes, it is easy and straightforward. Just follow the instruction included and you will be fine.
  10. leo5111
    what players have you used with it? is poweramp any good with it?
  11. DynnoG
    I haven't tried Poweramp yet. My mainly used player is Neutron and I am satisfied with it. Oddly enough, Neutron is the only player that transmit the song's metadata to my car's Bluetooth, so I kept on using it instead of HiBy player or Mango player.
  12. leo5111
    well back when i played music on phones i have Poweramp bought so id just have to sign in and install it
  13. leo5111
    well its here but battery is super low so im letting it charge
  14. leo5111
    do i set up sd card for internal or as portable?
  15. Arghavan
    If you set it up as internal you can install apps on it and the OS recognizes it as internal storage; but you shouldn't remove it from the player. "as portable" is like sd card on most DAPs, you can't install apps on it but you can hot swap it with other cards easily.
