iBasso DX150. Dual dacs and interchangeable AMPs. **NEW Firmware that supports AMP9! ** New FIRMWARE 1.05 Dec 30.
Discussion in 'Portable Source Gear' started by Paul - iBasso, Mar 9, 2018.
143 144 145 146 147 148 149 150 151 152
154 155 156 157 158 159 160 161 162 163
  1. XP_98
  2. pranavtripathi
    Anyone here has upgraded to DX150 after using DX80 or has listened to both of them?
    I have been using DX80 for more than 2 years and have been looking to upgrade to an android based player for streaming and bluetooth functionality as well. Could anyone please comment on the sound quality difference between the DX80 and DX150?
    Any suggestions would be helpful!
  3. gc335
  4. XP_98
    Yes, but should be the same for USB cables... And some claim they hear a difference... (I have a USB curious cable Hugo link since a few days, and have a feeling I can hear some différence too).
    So why not for coaxial cables ?
  5. XP_98
    Another question : I plan to use the Dx150 only as a digital transport for my Hugo 2, with Neutron or UAAP for the parametric equalizer.
    What would you recommend as alternative ROM (or kernel) ?
  6. TBomb06
    No. If you want to use Mango mode you'll have to stay with the 6.X release.
  7. XP_98
  8. leo5111
    how is the sound of this vs the ak100ii??
  9. Bookbear
    I found I had to remove the factory installed screen protector (I know, I know) to get it to register any touch (this is probably something to do with me, I've had the problem with other capacitance-touch screens). Once the screen protector was removed, all was well, only misses occasionally.
  10. XP_98
    Any advice ? Who has tested ?
  11. crazyeyes
    So I've had my DX150 a little over a week now and it has about 160 hours of burn in on it now with either the burn in cable or a set of headphones that I was listening to. How long do you guys recommend burning in the DX150?
  12. pranavtripathi
    I don’t think the sound will change that much now, so I guess you should pair them up with different headphones now?
    What amp module are you using?
  13. crazyeyes
    If that was a reply to my post? I am using Amp 6. I eventually would like to get Amp 8.
  14. pranavtripathi
    I think it should be fine to start pairing them with headphones and compare them to other players?
    I shall have the DX150 in a few days as well.
  15. leo5111
    nobody? i like the sound of my ak100II wondering if the ibasso dx150 will sound better or not
