TheoS53
- Mar 17, 2014
I've never understood why some insist critical testing for someone else to describe what they believe they're hearing. The entire ordeal of most all of this is subjective anyways. It's like somebody saying something tastes like vanilla. Well what other foods and flavors did you eat and taste to be sure?
Well, I suspect you then have no appreciation for the scientific method and discovering objective truth.
It's important to ask such questions in this case when trying to determine whether it's the architecture of the balanced output that is responsible for the differences heard, or if it's simply down to the increased power. If it is the latter, then simply increasing the amount of power (volume) in single-ended would yield the same improvements heard from the balanced connection....hence the need to double check that the volume is matched when making a comparison in order to exclude that as being the contributing factor.
It's amazing how people can have such a narcissistic and religious approach to something so simple.
